Maytag air conditoner
When I turn on the air conditioner (12,00 btu) the fan stops spinning nd no cold air comes out. How do I fix this? The window unit is only 3 years old.
Lilliyan77@yahoo.com,i am work in aircondioner (a\c tec)
Posted on Aug 07, 2008
  • 1,420 Answers
Unless you can see if the fan is hitting something, you can't. You will need to take it to a repair shop. Sorry.
Posted on Jun 09, 2008
My 5000 BTU GE window AC is making sporatic loud popping or cracking sounds when the compressor is on and running. It has stopped blowing air! When I put my hand in front of the air vent I can feel cold...
Fan inside blower unit stuck or seized. The compressor noises are because liquid refrigerant is coming back because it's not picking up heat from the room. Check/ clean the filters and spin the motor of the fan WHILE SWITCHED OFF. If it spins, it's probably the fan capacitor. If it doesn't, get a new fan
Aug 07, 2012 | Heating & Cooling
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
My LG LWHD1200FR air conditioner turns on, but the fan doesn't spin and no cold air comes out. What's the problem? How do I fix this?
Which fan doesnt spin the inside fan or outside fan? If its the outside fan try replacing the dual capacitor for the fan and the compressor. First take the fan blade and see if it spins freely if you spin it and it stops immedietly the fan bearings are bad. If it spins freely replace dual capacitor. If trhis helps please rate me and do a testimonial.
May 31, 2011 | Heating & Cooling
AC fan not turning on
take you meter and see if you are getting power to your fan motor, if yes then replace fan motor
Jul 21, 2010 | Maytag M7X06F2B Air Conditioner
How do i reconnect capacitor cbb65a-1 from my haier esa3125 12,00
The wires usually just have connectors that push on/pull off. Some capacitors run the fan and the compressor and have 3 different terminals. It is very important to make sure the wires get put back on the right terminals on this type. You can find a capacitor at a local heating and air store.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
Compressor comes on, some cold air, no fan?
Try spinning fan by hand. If it spins freely, change capacitor. If fan is tight, change fan motor.
Apr 08, 2010 | Fedders AED24E7F Wall/Window Air...
I have a sunbeam 12000 btu window unit air conditioner. I can't seem to change the fan speed when it is in cool mode. When I put it on fan only it blows extremely cold air and i can change the fan speed. ...
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
Jul 29, 2009 | GE Profile ASM10AA Air Conditioner
How do I make my air conditioner come on?
fan either collapsed on bracket or there is something stopping the blades from turning... other than that fan capacitor stuffed
Jun 15, 2009 | Star 8000 BTU Electonic Window Air...
I have a Maytag A/C window unit model number M6Y14F2B , 14000 BTU and on the display screen its showing a error code of EE. I would like to know what this means and can it be fixed.
Why should I tell you how I fixed the problem for free if you can't even tell me how to solve this problem for free. I just wanted to know what the error code meant and if it can be fixed or is the unit junk.
Jul 28, 2008 | Maytag Heating & Cooling
Kenmore Window unit 15,100 btu, Model 25372156200
with the hum noise sounds like you have a bad fan motor
May 26, 2008 | Maytag M7Y15F2A Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
