Question about Samsung WEP200 Headset
My blackberry pearl doesn't find my samsung bluetooth
Hello I just bought my bluetooth and the place a bought it they installed it for me. Now I just recently lost my ph and I can't get the head set to find my ear piece? Can you help please?
  • traceypen673 Mar 10, 2009
    my bluetooth is plugged into my tower, and i'm trying to pair my blackberry curve to it. the blackberry is saying no new device found??
    Genius:
  • 1,224 Answers
When searching device bluetooth
press and hold power button down on bluetooth this will sync the bt. up then put in the code 0000 for the pin it asks for
Posted on Jun 12, 2008
Unlock blackberry pearl 8100 Model: Blackberry pearl 8100 Pin: 25160503 Imei: 356920018929637
you can unlock your Blackberry PEARL 8100 eaisly with Blackberry Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry Unlocking Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
May 20, 2011 | RIM BlackBerry Pearl 8100
I cant receive anythin om my bluetooth yet i can send,,,my device cant be paired
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
Mar 11, 2011 | RIM BlackBerry Pearl 8120 Cellular Phone
Who to install blackberry theme
Checkout www.mobile9.com for Blackberry themes.
Connect your USB cable from your Blackberry to your PC or via Bluetooth if your PC is Bluetooth enabled. Then after you must have downloaded it to your PC, you can transfer it to your Blackberry.
Best regards
Aug 12, 2010 | RIM BlackBerry Pearl 8100
Not supported to audio in samsung sgh i900
quiero reiniciar mi bluetooth ioval para poderlo parear con mi blackberry pearl pero anteriormente estaba activado en otro blackberry y le pidio una contrasena se ha quedado esta clave como podria reiniciar mi manos libres
May 24, 2010 | Itech i.Tech i.Oval 303 Bluetooth Headset
I have just brught an unlocked blackberry peael 8100 and i do not know the bluetooth unlooking code could you please help IHave just brought a unlocked blackberry pearl but i do not know the bluetooth...
Hello
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Apr 04, 2010 | RIM BlackBerry Pearl 8100
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
Pairing headset with Blackberry Pearl
On my blackberry I have to turn bluetooth on. Then on the WEP 200 hold down the button untill you hear a series of beeps. The light should blink every so often once its on. Then go to bluetooth options and search for devices.
Jun 07, 2008 | Samsung WEP200 Headset
Bluetooth for Blackberry Pearl!!!!
I use to get that messege because my phone didnt have enought memory for the transfer. I bought the memory card so now it's fine.
May 09, 2008 | RIM BlackBerry Pearl 8100
Samsung WEP200 Headset Logo
135 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
