Question about 2wire 2700HG-B Router (2700HGB)
Use 2700 as router only?
I have a 2700HG-D, which I have been using with Qwest DSL service. I am now changing to Comcast cable service, and I will need a wireless router. Is it possibe to use only the router feature of the 2700? Can I connect the cable modem to the 2700 somehow and get a wireless signal? I'd like to avoid buying a new router if possible.
  • Gillmore Jul 23, 2008
    I am just wondering if this solution worked on your 2wire 2700hg-b? Let me know i dont want to brick my router.
  • pattheref Oct 17, 2008
    I did not try the suggested solution. It sounded too complicated and too unsure. I found a good D-Link wireless router on sale and used that.
I am also facing the same switch from Qwest to Comcast... and yes, I too have a 2-Wire Gateway 2700HG-D. Did this router configuration work? If it's not reliable or unstable, I guess I'll need to opt for a new wireless router. Thanks in advance!
Posted on Oct 17, 2008
  • 143 Answers
There's a way to make the gateway act as a router only but it's not really recommended since there's a possibility that the connection will not be as stable as it should.
anyways you can try the following steps in making your gateway act as a router (not really a router but just a switch and a wireless access point).
- access the router's web user interface by typing on your web browser
- then click on the "Advanced Configuration Settings"
- select the "Transparent Bridging" option (note: you must configure your wireless settings first before trying these steps since you might not be able to access the gateway's page anymore once you save the changes)
- set the vpi to 0 and vci to 32 if it asked you for those settings. next to 'ATM PVC Search' select the radio button next to Disable. ensure Bridged LLC is selected next to 'ATM Encapsulation'.
- then save the settings
- connect now the new modem to one of the ethernet ports of the 2700hg-d using an rj-45 or an ethernet cable
hope this'll help you.
Posted on Jun 10, 2008
The dsl light keeps blinking red no Internet connection
for LED LIGHTS interpretation: refer to this link:
NOTE: everything that says contact SASKTEL TECH SUPPORT refers to your Internet Service Provider
Qwest Technical Support at 1-800-247-7285
SASKTEL TECH SUPPORT Anywhere in Saskatchewan :1-800-773-2121
Outside Saskatchewan (anywhere in Canada and USA):1-888-773-2122
Anywhere else in the world:1-306-522-1820
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Hope This helps
Aug 14, 2011 | 2wire 2700HG-B Router (2700HGB)
Can i use whis product with comcast cable modem
If this is a cable modem as you say, of course you can use the AT&T product on the Comcast cable line even if they are compettors.
The picture you post (or rather, the picture that was posted with your question) states it is a DSL modem (Data Subsctiber Line) aka 'digital' which you cannot use with a cable based modem.
I guess there is that possiblity that yours can do both, but I can neither confirn nor deny this.
Thanks for the clarification
Dec 08, 2009 | 2wire 2700HG-B Router (2700HGB)
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
Will a 2 wire dsl router 2701HG-S work with cable modem
No, not the way you want it to. The wan(internet) port on the 2701 is an rj-11 that will only connect to a phone line with DSL service. There is no way to use this as a router with your cable modem. You need a router that has an ethernet (rj45) port as the wan port.
Oct 05, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use a 2700 router with Cox cable input? I have a 2700HG-D with "Qwest" logo on it; where can I find software so my laptop will recognize the router?
only if it has the proper IOS and hardware interface module. What do you want to use it for?
If you have a Cisco console cable (light blue ribbon cable) there is a console port on the router, and the other end connects to a serial port on your PC (or a USB to serial converter) using hyperterm set for the correct COM port at 9600 Baud 8 bit no parity 1 stop bit (8 none 1)
If you don't have the password you can crack it but it's complex.
Aug 18, 2009 | 2wire 2700HG-B Router (2700HGB)
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Foce 2wire
Most device/routers/wireless devices that were specifically used by a different provider are not interchangeable unless this specific device can be given a firmware upgrade. If you were previous provider was Qwest, you probably had DSL service and now you have cable? Your best option is to purchase a new wireless device you can attach to your cable modem through Comcast. Good luck!
Apr 02, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
1,658 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
