Question about Pioneer PureVision PDP-503HDE 50 in. Plasma Television
Plasma e01 error
Saw ur note about the pioneer plasma e01 error. mine just starting doing that. about 4 yrs old
are u serious about ur solution that its just a wire resolder problem near the power cable ? or did u find some other problem ? i thought it might be related to overheating. but ur suggestion sound interesting
pls email me if u have discovered any other ideas at
  • 5 more comments
  • bjonda423 Sep 21, 2008
    EO1 error
  • Anonymous Oct 29, 2008
    I have the same
  • Tomcat511 Nov 15, 2008
    TV shuts off itself off sporadically and displays E01.  Im ready to chuck it out the window.  Can anyone help?
  • Professor1 Nov 28, 2008
    same tv same problem. Who can fix it?
  • whiff smith Feb 02, 2009
    yep exactly the same symptoms and still can not find a solution.
  • Anonymous Feb 15, 2009
    I have exactly the same problem, why cant pioneer give the answer?? this is their error code and all theses blogs give you different repair methods, i dont want to make it worse. does anyone have a sure fix from pioneer what to do??
  • Anonymous Feb 28, 2009
    same problem with my pioneer 43 in!
Hi. Had all the symptoms with my Pioneer 43" plasma with RO3E receiver that have been previously posted. I got so fed up with it turning itself off that i decided to take the top off the receiver and look for the dry solder joints on the power supply board that some have posted to have cured the problem. I removed the power supply board (which involved removing an interface unit which is mounted above it) and found no issues. I then proceeded to remove the switch board which is placed in front of the power supply board. When i removed the electrical connector which i found not to be fully inserted, i noticed that there was a brown burnt stain in the middle of the connector plug indicating a possible poor connection. I removed the electrical connector from the unit completely (the other end connects to the adjacent board with the fuse on it) and cleaned the connector plug with electrical cleaner and re-inserted it into the receiver and built everything back up. I am happy to report that the tv starts up first time every time and has not turned itself off since. I have included a picture of the offending plug in its built up state (it is the one with the row of black wires with one red wire). Do not attempt to do this unless you are suitably qualified.
Posted on May 20, 2009
I have a pioneer plasma tv about 2 yrs old.It goes to standby mode every 30-40 min.Even when shut off it will return to stdby???Thanks
check batteries on ur remote even hide it in other room/if not it could be power supply over heats it
will shut down/another thing go to menu reset to factory default.
Jan 05, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I have an E01 error message what is it and how do I fix it
I have an E01 error message what is it and how do"tv pioneer pdp-503pe"
Nov 20, 2009 | Pioneer PureVision PDP-503HDE 50 in....
The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Aug 19, 2009 | Televison & Video
Pioneer Plasma
hello have you got a media box if so id check the it for dry joints in the power supply good luck
Apr 04, 2009 | Pioneer Televison & Video
My pdp r03u has an error code e01
I have a 50" Unit with this same part, I called Pioneer and told them what was happening, they asked me to count the flashes on the monitor power indicater light and when I told them the problem they told me that it was a dry solder weld, I called a tv repair tech and told him what was going on, he had never worked on Plasma Tv's and was very hesitant to start I told him if I just brought in the Media Box and had him check the solder joints how much would he charge he told me to try he wouldnt charge me anything, I jumped on that! he saw a few issues and fixed them, I brought the unit home plugged it into the tv and the tv works just fine!
Oct 24, 2008 | Televison & Video
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer Plasma
maybe you can bring it at any pioneer service center and have the IC's can try that...
Mar 12, 2008 | Televison & Video
Open Questions:
See all Pioneer PureVision PDP-503HDE 50 in. Plasma Questions
Pioneer PureVision PDP-503HDE 50 in. Plasma Television Logo
1,864 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
