Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel gwl11 power does not come up.
OK,
I have tested all the basic, power from panel, change outlet and check the power at the main controller and yes I can measure 118 V. But "pickel" does not provide electronic diagram ... so I open the controller to see for obvious fuse and no fuse. So I am stuck and I am asking the expert before I call the service man and charge me arm/leg to replace panel. I now really questioned the quality of this product.
  • 7 more comments
  • tmb1226 Jun 24, 2008
    I filled wash machine and came back a few hours later to a washer full of clothes and water. No power at all. I checked fuses, and the outlet is good.
  • tguinnmo
    tguinnmo Jun 25, 2008
    2- 1/2 yr old gwl11 stopped in middle of spin cycle. outlet is good & cord looks like new still. repairman ($$$) will be out in two days to fix (hopefully)...
  • KWheel Jun 28, 2008
    Same problem - washer stopped in middle of washing. Now does not seem to have any power although power applied measures fine. Can't find a fuse so will have to call repair service for 3 time in 1.5 yrs. They always come and fix it but I'm getting tired of requiring it. Surely there is a fuse somewhere?
  • Anonymous Jul 02, 2008
    I was setting up my F&P GWL11 to wash when it stopped responding. I think a voltage spike got it. It will not turn on even after unplugging it for several minutes, as per instructions. It will be more than two weeks before I can get it serviced. I have liked my F&P very much (about three years), but the lack of service in a reasonable time and the high cost of repair parts are causing me to reconsider the practicality of this machine. I would consider replacing the control module myself but I have only found one place to get it for $342.00, a major portion of the cost of the machine. I still have hopes that this could work well if I use a good surge protector.
  • ualani Aug 14, 2008
    Same washer GWL11 and appliance repair friend of mine said there id not a seperate fuse for washer. Fuse is built-in to the control board. Have not got a cost for new board yet though I may look at board a little closer to see where in board fuse protection is. If possible I may unsoder and replace with one from radio shack. Washer is just under 3 years old.
  • Anonymous Sep 01, 2008
    Washer shut off in the middle of a cycle and will not power up. Water on floor. Pull plug and tested power to outlet. Power is good.
  • Anonymous Mar 08, 2009
    My machine is under 4 years old and I have the same problem. Machine filled up and did not advance. Would not power up. All my other machines lasted a minimum of 15 years. I'm going back to a "real machine".
  • Anonymous Mar 14, 2009
    I had the same problem with the GWL11... Cheap water pump seal went... got motor wet... and shorted out the 3amp fuse on the board... (Fisher Paykel want $50 for the service manual, which really irritated...) Ordered new pump... replaced fuse on board with a car stereo fuse... Thsi worked fine for a while, the the fuse started blowing half way thru the spin cycle... We have been replacing the fuse as nec. until I get a chance to investigate further.
  • cdrstang Mar 24, 2009
    My GWL 11 had been making an intemitten loud noise for months. We had a repairman and it did not make a noise when he came. The machine continued to make the noise at random times until the other day when it did not drain and will not power on. Does the control board and drain pump both need to be replaced? I tried to contact Fisher & Paykel with no response.
The fuse is built onto the control board. It is not designed to be replaced. My 3 year old machine lost the water pump and blew the fuse. About $375 to fix. I am buying the new pump and will attempt to replace the fuse on the board. I hope there are no other bad components.
Posted on Mar 02, 2009
My 4 yr old f/p will not turn on...no lights, no sounds...nothing. I changed out the Pump drain motor because somehow water dripped on it and it burnt out. Seems like alot of people with the same problems. F/P should fix all these same ocurances for free. A high quality machine should not do this. This reminds me of Acura MDX's with bad transmission problems. Everyone had problems but they won't warrant for over 100,000 miles. Mine went out at 105,000 miles and they **** big time.
Just like f/p does.
Posted on Nov 13, 2008
Ouch, too bad. Ours just did the same thing. It's seven years old now, and has already had a couple service trips. Seems like it's time for a front-loader.
Posted on Jul 22, 2008
Turns out this problem is common to the GWL11. The water-pump goes out which then causes the circuit board to fry. It's unclear as to why one begets the other. Cost for a repairman: $272.00 in sw MO. The good news is that F&P has re-dsigned the waterpump to eliminate the early failure issue. Bad news is that it doesn't interchange with the GWL11 :(
Posted on Jul 04, 2008
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
I've got a Fisher Paykel top load washer GWL11, no lights on panel, nothing, I've checked power it's ok, no lights at all...any idea's?
The main fuse in the Motor Control Unit will have popped. A new control unit will be required or maybe take it to an electronics wizz. Check on ebay for new unit. Make sure you get the correct part number which is printed on the white sticker . Undo the 2 screws at the back of the buttons panel and lift off. The control unit is the brown box underneath with all the wires connected. Also.....first check all plugs are attached properly and try again.
Aug 07, 2014 | Fisher and Paykel Washing Machines
Why won't the power panel light up? Checked electricity to machine. It's ok
it maybe the motor driver board has a fault and not sending power to the board. see if you can get it tested..
Oct 09, 2013 | Fisher and Paykel GWL11 Top Load Washer
Gwl10u2 fisher paykel washer iwl15 can't get it to turn on? Checked the outlet,it's ok. Tried another outlet, still nothing! Help!!!
the fuse on the motor controller has blown. you can replace this fuse, but you will most likely have a short circuit / fault in the pump or motor. check for signs of wear on these, and check for earth faults before re powering machine with new fuse / motor controller.
Sep 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
No power
possible faulty module. did u check fuse on circult board? water proberly coming from faulty water valve.u need 2 find where water is coming from b4 u install repaired circuit board.please reply 4 more help
Apr 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
No power to the machine control panel. There is power to the cord. We have tested that. Power button does not turn on one light.
Motor control board is blown. Before replacing it, make sure the main seal has not failed, and check motor and pump windings not burnt.
Mar 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel washer press power button but nothing happens.
you have a blown main power module I can talk you through testing this machine for a secondary fault and replacing the module in live chat
Mar 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
2,269 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
