Question about Whirlpool Washing Machines
Drum pulley is lose on the main shaft, when drum changes direction the pulley pauses and then goes in the other direction, there is some wear on the main shaft where the pulley is mounted,
  • 1 more comment
  • shellyray Jun 12, 2008
    yes this is a front loader, you are right,the nut came loose on the pulley,and that took the bore out of the pulley but it also shows a little wear on the steel shaft. my concerns are that the new pulley will be loose on the shaft.so when the machine is in operation and changes directions with a loose fit it will do the same thing to the pulley, do you recommend any kind of a filler product?. thank you for your help
  • shellyray Jun 15, 2008
    thank you for getting back to me, am replacing the pulley and putting on a new nut with the blue loc-tight. our best to you
  • Richard
    Richard May 11, 2010
    Is this a front load Whirlpool Washer? If it is, The shaft is not worn (made of hardened steel) most likely the pulley (made of aluminum) is worn. The pulley usually wears because the nut comes loose. Is the nut Loose?
  • 413 Answers
You should not need a filler, the shaft is is made of hardened stainless steel and should be OK. When replacing the nut, use BLUE loc-tite on the threads to ensure it won't come loose again. Also, when tightening the nut, DON'T use your hand to hold the pulley, you could injure your fingers...instead, stick a block of wood between the pulley and tub.
Posted on Jun 12, 2008
Dryer tries to turn but then shuts off
Hi espichfamily
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley this will cause the drum not to roll.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Oct 11, 2012 | Amana NED7200TW Electric Dryer
I have a dryer serial number DMM202481G. Must be 7+ years minimum. It is squeeking. Is it worth repairing. Probably ball bearings of some sort.
Hi jbukowki1...
It is probably your drum rollers that need lubricant, and easy and cost effective fix.
Follow the directions below:
Your problem sounds like the drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Aug 24, 2011 | GE Dryers
Drum is making alot of noise as it goes around . what do I look for?
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 13, 2011 | Kenmore Dryers
Extreme rumbling,vibration have it apart whats the best way to tell if the drum is out of round or the rollers are shot have cleaned vent and motor. motor runs smoothly on its own
You rotate the drum rollers looking for an eliptical outer surface rubber of the rollers. Also make sure the rollers do not teeter fore and aft on the roller shaft.
Next grab the idler pulley for the belt and see if there is any play in the ldler.
Worn drum felts / gaskets or a front bearing glide can also contribute to the problem
See this link for parts:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47834&diagram_id=28471897#d28471897
Item numbers you need to check are
6, (unusual wear)
14, drum gaskets {2 ea front and rear} (torn, worn or folded)
18. Just replace the belt if your into it this deep..... especially if the dryer is +5 years old
23, (roller Shaft for wear)
24, roller for wear center and outside surfaces
30. Drum glides (Kit)
A rumble is usually associated with a bad fan blade...as in the center of the fan blade hub is cracked or broken. Check the fan for play.. also hold the motor drive pulley and see if the fan rotates on the motor shaft. It should NOT rotate without turning the drive pulley
A squeal is associated with the belt or idler pulley
A thump is a drum/felt/roller/glide problem.
Thanks for choosing FixYa,
Kelly
Jan 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a squeaky sounds durning cycle, it comes and goes, sounds about the same speed as drum is turning
pulley and motor.
Please rate me
Dec 27, 2010 | GE DSXH43EAWW Electric Dryer
Sgueaky
pulley and motor.
Please rate me
Dec 04, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer rotates fine but it makes loud clunking sounds as it spins. Sometimes it pauses for a rotation and then starts in again. The belt was replaced recently and the back 2 rollers spin freely. The...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 04, 2010 | Maytag Dryers
My washer will wash and rinse the clothes, but won't spin. what is the problem?
Sounds like the Thrust washer problem to me. I believe this to be basically a Maytag single belt washer. Your symtoms sounds to me like the brake package is is not releasing the tub. Their is a cam riser built into the main drive pulley on these washers. The motor runs in one direction for wash and rinse and another direction for spin and pump out. In the spin direction the brake is released and the drum can rotate. With time the main drive pulley wears out. A new pulley and washers comes in a kit to fix the problem. More here
Aug 27, 2010 | Admiral AW22 Top Load Washer
My gas dryer has a loud squeal that starts part way through the cycle, the goes away sometimes.
Good Luck,
I hope this helps
Please rate me,
Thank You
Aug 14, 2010 | Frigidaire FGQ332ES Gas Dryer
I have an kenmore dryer i have the belt hooked up through the pulley but there's a clip on top of the drum i can't figure out how to clip it to the belt. The dryer runs but won't spin and the belt keeps...
make sure you got the belt the correct way the little teeth need to be down on the drum that is usually the main problem haS happened to me before and make sure you got it the right way the right side of the belt goes under the pulley with you hand bring the pulley closer to the motor shaft as your doing this there should be a lot of tention where you can barely get the belt on the motor shaft if its way too easy its not right and make sure your belt is not in the crese of the drum once you bring the pulley closer to the motor shaft just hook the belt around the shaft good luck
Jun 06, 2009 | Dryers
Washing Machines Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
