Question about Kenwood Audio Players & Recorders
Kenwood kdc when i turn it up to 23 it shuts its self off and then it comes back on.
You have a bad cable going to what ever your using when it turns off or you have one of the speaker cables cross somewhere
Posted on Jun 09, 2008
I have a Kenwood KDC-MP435U radio in my car and when ever I turn in up kinda loud it will shut off and come back on on its own. Any idea why this is or how I can fix it?
The wattage of the speaker is higher than the required wattage of the stereo. The stereo cannot drive the speaker very well. Use an amplifier if you want to have a loud sounds. Or if you already have sound set-up make sure that you have a capacitor for your amplifiers and fuses to support the power input to your stereo.
Apr 07, 2011 | Kenwood KDC-MP435U CD Player
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Kenwood new sterio shuts off when turning up volume
You may have a short in a speaker. Check to see that the wire terminals on the speaker itself aren't touching any metal. Even 1 terminal touching metal will cause issues. Hope this helps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
When I turn off my car my stero resets all it's setting
Mike
Here is a owners manal and wire diagram on page 55. You have the yellow wire hooked up wrong need to put to a constant hot not one on a switch.
http://inform3.kenwoodusa.com/manuals/KDCX889.pdf
Good Luck
Dec 18, 2008 | Kenwood KDC-MP628 CD Player
Kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
Kenwood kdc 3011 cd player
Have you tried the balance and fader control?
Also make sure the ground or - negative wire has a good connection for that speaker from the back of the unit. Or it could be the internal amplifier it self.
Dan
Aug 17, 2008 | Kenwood KDC-2011S CD Player
Kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
May 27, 2008 | Kenwood KDC-2011S CD Player
Kenwood KDC-MP3035
make sure you have 12 volts into the radio at high volumes mine shuts off when i turn it up over 25 due to power draw
Nov 18, 2007 | Kenwood KDC-MP3035 CD Player
Kenwood KDC-MP228
Your ground is weak or your running your radio at low voltage. Good Luck
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Wiring diagram
Manual is here; http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-4021~3021~306~2092%20(EN).pdf Page 23 has the wiring info. Best of Luck.
Sep 26, 2007 | Kenwood KDC-4021 CD Player
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
