Question about Canon CanoScan 4400F Flatbed Scanner
Reinstallation Computer crashed week ago, had to buy a new tower. Unable to locate the original installation disc. Help....please!
  • Anonymous Jun 11, 2008
    lost the cd from my scanner. computer crashed new hard drive no software. Cheers Andreas
    Problem Solver:
  • 7 Answers
Always get the original manufacturer's drivers directly from their website. Be sure to select the correct Operating System (like XP or Vista or Mac OS).
Canon CanoScan 4400F Drivers
Thanks for rating this Solution!
Posted on Jun 09, 2008
2 weeks ago I had to crash my computer. the eRecovery solution say it installing but it stuck at 13/14 and has been that way since I crashed it
Hi please explain what you mean by
i had to crash my computer
what went wrong with it and why did you try the recovery
Mar 25, 2011 | Acer Aspire 5315 Notebook
The hard drive crashed will not start
If the hard drive have crashed meaning that the hard drive itself is damaged, then your solution is to replace a new harddrive. If you do have a recovery disc already made, or one is provided then you will have to use that disc once the hard drive is replaced with the new one, and follow the procedure to reinstalled the operating system. If the original hard drive had crash and does no work anymore (where the bios/computer cannot detect it) and you have important data that you would like to retrive, there are places such as office depot, bestbuy, where they can help you send it to a recovery file center to recover files from your damaged hard drive. Do not attemp to fix or open a damaged harddrive, you can forever damage the files on the cyclinder disc. 2) Now if your harddrive crash in term as windows just crashing and you cannot get into your operating system and the bios is still able to detect the hard drive, and it's giving you a error message, then you will only need to reinstall, or do a windows recovery through your recovery disc, If you do not have a recovery or made the disc, then you will need to buy a new operating system software. If you computer does not start meaning no display on the screen at all, then please replay back. That is a different story.
Feb 06, 2011 | Acer Aspire 7720-6569 Notebook
Installing windows xp into acer aspire m1640 need help the computer is falling to boot intead is showing a blue screen
The blue screen represents your Windows XP hasn't failed to install but has crashed and given you an error. The only way to fix this is to restore it to the original Windows and than try again. This mostly happends with boot leg copies of Windows XP and speaking from experience your better off buying the disc from the store so if this ever happends again your covered. If you DID buy the disc, then talk to your supplier and they should give you a new copy or install it for you.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 24, 2010 | Acer Aspire M1640 Refurbished Intel...
APPCRASH error please help
When program files or files within your computer's registry have become corrupted, this can cause the programs to unexpectedly crash. When a program crashes, you will likely get an Appcrash error. The error message will say "Windows Media Player (or whichever program has crashed) has stopped working" and then list rows of technical information regarding the cause of the crash. Unless you are a computer programmer, you may never fully understand what caused your program crash, but that doesn't mean that you can't fix it.
Delete any new programs that you have downloaded. Often, the cause of corruption in a computer system are bad downloads that bring harmful files onto your computer. If you started to get the Appcrash error on your system after downloading a new program or software from the Internet, it's highly likely you have downloaded a bad product. Use the "Add/Remove Programs" feature in your "Control Panel" to get rid of the program immediately.
Uninstall the program that is crashing. It is possible to fix the program's corrupted files while the program is still installed, but to make sure that you clear the program files completely, it is safest to completely uninstall it from the system.
Run a full scan of your computer. Your computer should already have antivirus software installed that can scan for corrupted files and either fix them or delete them from your system. If you do not have antivirus software on your computer, that could be a big part of the problem. Purchase and install antivirus software as soon as possible. These are designed tor from outside threats. Once you have the antivirus program installed, open it and click "Scan Computer." The antivirus scan will isolate bad files and you will be given the option to remove them from your system.
  1. Reinstall the program that was crashing. Now that the corrupted files have all been removed, your program should run smoothly after reinstallation.
  2. Check for program incompatibility. If, after a thorough scan and cleaning of your computer and reinstallation of your program, the Appcrash errors continue, the program you are trying to use may not be compatible with your program. For instance, there are some DVD softwares, such as Media Now, that do not work correctly with Windows Vista. These lists can be easily found online. If this is the case, you will have to purchase a software program that is compatible with your OS
You should download a program such as RegCure and run it from time to time. If you are unable to download a copy let me know and I will give you a link on my web where you can download it.
Jan 16, 2010 | Microsoft Internet Explorer 7
My laptop is unable to read external device (disc of photos). Had ability to do so until hard drive crashed whilst still under warranty (no longer under warranty now). The only drives on computer now are...
Make sure that your source disc is compatible with your drive. if it has a dvd, then you can use dvd disc.
Also, try to download and install the DVD/CD driver for your laptop.
Nov 25, 2009 | HP Pavilion DV6700T Notebook
Have been directed to find my Serial number for my Gateway deskto
Hi
Thanks for using FixYa. The serial number is usually located on the top, left, right, or back panel of the computer. The serial number is printer on a black sticker with white lettering.
Also see this link for Serial code location--
Gateway Computer Serial Code Location
Also see this link for more info--
Gateway Computer serial location
And if you are unable to locate the serial code anywhere then right click on My computer icon on desktop, then click on properties and from there you will be able to see the serial number from there.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 28, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Due to a virus I had to crash the computer. The
You will either need A) a new network card / some other method of getting online to get the drivers / software B) the original discs that came with the computer to restore from C) a phone call to dell support to request the software.
Jun 24, 2009 | Dell Ethernet Card Network Adapter
Hard drive.
since that it crashed, it is more practical that you reformat it, rather than buying new one. it is the system crashed not the whole hard disk and there is a great chance of reviving it , you have the recovery disk with you, then better use it than buying.
have a nice day
ally (allen)
Jun 27, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
DS-2 Olympus Digital voice recorder
You can buy the disk but there is a download. DSS Player (version 7.0): is available via download as a courtesy, please follow the instructions below: http://www.olympusamerica.com/files/DSSPlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
Serial #:(8360-0101-0027-7420-4735 )
Jun 22, 2008 | Olympus DS-2 Digital Voice Recorder
Canon CanoScan 4400F Flatbed Scanner Logo
145 people viewed this question
old marine
old marine
