Question about HP Pavilion 8860 (P2941A) PC Desktop
Blank screen(beeping sound)
Power runs trough my monitor and cpu, but my monitors shows nothing and my cpu makes a long beeping sound after a few seconds.
  • powee Jun 09, 2008
    HELP ME DUDEZ
  • whyteboxer1 Feb 17, 2009
    my computer starts up and after the blue screen that say HP shows up it makes a long seris of beeping.I tried to clean out my computer memory like stated.Nothing has happened.How else could i fix this without spending a bunch of money or having to replace my computer?
  • 458 Answers
1 long beep is usually graphics card..
try booting to external monitor... connect your laptop using the serial port or by S-Video cable to a desktop monitor or similar..., then press FUNCTION and F5 to switch to the external monitor, if the laptops Screen is viewable on the external source.... then it is a bad video card...
Posted on Jun 09, 2008
    Scholar:
  • 49 Answers
Hi Powee,
It's definitly a memory issue. What you might wanna do, is open your CPU and take out the memory sticks from the memory slots. After this, try either blowing or vacumming (if you have one of em small PC vacumm cleaners) the slots whcih contained the memory sticks. Also, dont forget to blow off any dirt that might be on the memory stick(s) itself.
After this, just insert the memory stick(s) back into it's slot(s) and try to rebppt your computer again. Most of the time it should work. However, if you still face this issue, then it means that your memory itself is corrupt and you might need to buy a similar capacity memory altogether.
As a side note, if your computer comes from a manufacturer like dell or acer, you might wanna get them to look into the issue if it;s still under warranty (or even if it's not). Certain "branded" computers have their own way of functioning. Hope this helped.
- Technomancer
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
Blank screen on my monitor. Need help plz.ty.
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem bye
Sep 13, 2007 | Acer AL1916W 19" LCD Monitor
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
HP Pavilion 8860 (P2941A) PC Desktop Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
