Question about Sony Playstation 3 (PS3) Console
Only one controller can work at a time
I have a ps3 and on call of duty 4 i can play with all the controllers. i haev rainbow six veags two and i can start the game with the controller it came with, but the other controller only works when i turn the others off. and i cannot play multiplayer because one controller will stop working. i can't play gran turismo 5 prologue with either of the wireless logitech controllers. i can go through the menu's but when i start the race, all's i can do is pause the game or quit it.
  • 27 Answers
You will need to pair the second controller. To do this power on your ps3 as normal with the controller that works, then plug in your second controller via usb and press the "PS" button. The red LED's should flash and then the second led should stay on.
You should be able to play normally.
Posted on Jun 09, 2008
I have a madcatz call of duty black ops controll, it charges when i connect it but wont connect to my ps3? help me!
You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
Jul 13, 2012 | Mad Catz Call of Duty Black Ops...
My kidere playing Call of Duty world at war and now My PS3 stopped working??
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Jun 20, 2010 | Dmm Call of Duty: World at War
Trying to play Call of Duty 1 playstion2 on PS3
Some games will do this if you are holding the control-stick any direction while starting the system.
Next time you play it, try holding the stick just slightly in the opposite direction to compensate as you start the system, or unplug the controller-hold the stick down, then plug back in ( while playing )
If that doesn't work, it might be time for a new controller. Or you could open it ( disconnect first ) and check around the stick for anything that might be pushing it up.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 Randomly Reboots while playing Rainbow Six Vegas
Sounds like you've got a data issue related to the hard drive.
You should use the Restore to Factory Settings option under SYSTEM.
This should address the problem.
Also does the machine feel hot or does it sound loud?
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
Can i have the phone number for the sony ps3 help line
PS3 when playing a game (Call to Duty 4), game quit, TV screen has black, white and gray vertical lines on it, disc will not reject, game control red lights (4) keep blinking, and PS3 not accessible.
Thanks
coc5th46@yahoo.com
Jul 16, 2008 | Sony Video Game Consoles & Games
Ps3 console freezing during game
check your HDD of ps3,is it full of memory cause for your kind information there is a program when ps3 needs more memory than its creates short time developed cash as memory on HDD so, if you ahve full HDD than reate some blank space on HDD for memory for barer performance,
i hope so you got mine idea,
if you still have problem than try to contact me .i illl....
THNX
May 17, 2008 | Sony Playstation 3 (PS3) Console
Call of Duty 4 no longer works
Take it back. I have had the same problem with my 40gig and many others are too. Sony has been having problems with the drives
Mar 24, 2008 | Sony Playstation 3 (PS3) Console
Game updates not downloading!
make sure latest firmware is on console befor downloading aditions to games!?
Mar 20, 2008 | Sony PlayStation® 3 (60 GB) Console
Ps3 controller left toggle stick
i dont mean to sound patronising,but your man can only run for a certain length of time....he needs to take a breather between runs,just like you would....
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Earpiece usage 4 warhawk ps3
lool...why do u type ur problems here...all ur problems can be found on playstation.com anyways....did u check ur NAT....go to network...connection status.....the last thing on that list....if it says type 3....ur using a highly secured internet connection...(firewalled)...and its blocking ashitload of ports...i have warhawk...and i know from what i'v heard...it needs a lot of ports to run i...thankfully dont have problems with the game
Sep 29, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
