Question about Apple iPhone Smartphone
Can;t use itunes unless enable iphone via passcode
Can;t do a restore because itunes ask to enable iphone so it can be use
My ipod is disabled and it says connect to itunes
Posted on Mar 27, 2011
  • 45 Answers
Enter DFU mode by holding the sleep (top button) and the home button for 30 seconds. Then plug your phone in, iTunes will recognize your phone and will ask you to restore it.
Happy Hacking
Posted on Jun 15, 2008
How can I get in to my iPhone 5s that daughter change passcode then forgot it
If you enter the wrong passcode in to an iOS device six times in a row, you'll be locked out and a message will say that your device is disabled.
Pick a way to erase your device
Unless you made a backup before you forgot your passcode, there isn't a way to save your device's data. You'll need to erase your device, which deletes all of your data and settings. Choose a way to erase:
  • If you've synced with iTunes, use iTunes.
  • If you're signed in to iCloud and Find My iPhone is enabled, use iCloud.
  • If you don't use iCloud and you can't sync or connect with iTunes, use recovery mode.
Mar 12, 2017 | Cell Phones
Forgot password on my old iphone 4s 16gb
It's the most frustrating thing for us to forget our iPhone password. In order to unlock and access your iPhone normally, you need to reset your iPhone password. Resetting iPhone password is not complicated.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
  1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
  2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
forgot-password-old-iphone-4s-16gb-oxaxc0rwhkhzilrwacqreyis-1-0.jpg After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
How to Reset Password on iPhone
Oct 12, 2016 | Cell Phones
How can i get passcode
Unfortunately there is no way to get your pass-code back.
You can reset your iPhone using your i-tunes on your computer. Unless you have a restore date that is before the pass-code existed you will have to reset your phone.
You could also try to reset your pass code through find my iPhone on icloud.com but this may result in a temporary unusable phone.
you can follow this link to reset your phone:
https://support.apple.com/en-us/HT204306
Hoped this helped my best wishes to ya.
May 24, 2016 | Apple iPad (16 GB) WiFi Tablet PC
How do I remove a passcode from an IPhone 4s?
Do you mean the network passcode?If so, to remove the restriction, I suggest you can approach Wickedunlock.com and specify the country,locked network of the iPhone 4S.Based on the availability you can get their permanent remote unlock service and remove the network passcode.
Sep 29, 2014 | Apple iPhone 4S
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
How to bye pass passcode on iphone
Your iPhone enables you to add a four-digit passcode which locks your phone to prevent unauthorized users from using your cell phone.
When you enable the passcode, your iPhone prompts you to enter the four-digit code before you can unlock your phone.
However, if you have forgotten the passcode and unable to use your iPhone, you can override the passcode using iTunes the default iPhone management program.
Restore your iPhone back to the default settings to override the passcode.
To do so, connect your iPhone to the computer using the USB cable that came with your phone and launch iTunes.
iTunes displays your device in the left panel under "Devices."
Click your iPhone under "Devices" and click the "Summary" tab.
Click the "Restore" button.
Keeping in mind that restoring your iPhone back to the default settings deletes all the currently saved information.
When prompted, click "Backup" to back up your iPhone.
Click "Restore" again and follow the final guided prompts to restore your iPhone back to the default settings.
When the process completes, click "OK." You should see the "Connect to iTunes" message on your phone.
Keep your iPhone connected to the computer until the "Connect to iTunes" screen goes away or you see "iPhone is activated" message on your phone.
Right-click your iPhone under "Devices" and click "Eject."
Close iTunes and disconnect your iPhone from the computer.
Your iPhone no longer prompts you to enter the passcode.
Nov 17, 2013 | Computers & Internet
How can you reset a forgotten password on the iphone a1203 phone
reset-oxaxc0rwhkhzilrwacqreyis-1-0.jpg How to Reset Password on iPhone
Jul 23, 2011 | Apple iPhone Smartphone
Cannot connect to itunes store (itunes 9) error 11222 i run windows 7 starter i've let itunes through my norton 360 firewall tried un/reinstall of itunes flushed my dns and i've cleaned my registry with...
Disable your internet security while trying to connect. Enable it after you have finished doing whatever you needed to do with itunes. You may also be able to include itunes and the itunes store in the websites acceptable to your internet security software.
Apr 13, 2010 | Apple iTunes
Ipod touch is disabled itunes won't connect says the ipod needs a passcode before connecting to itunes
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
Jan 15, 2010 | Apple iPod touch
Iphone disabled connect to itunes
Here are your instructions from the website below.
Reset your iPhone Passcode:
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number http://www.knowyourmobile.com/appleiphone/apple_iphone_userguides/4684/how_to_password_protect_your_iphone.html Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 28, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
1,035 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
