Question about Amcor Ultracool by 12,000 BTU Portable Air Conditioner and Heater
Amcor ultracool beeps and turns off
My A/C unit run for 1 hour, then it beeped a few time and turned off. Cannot turn it on again
  • fabiodivitto Aug 24, 2008
    I have exactly the same problem
2 Suggested Answers
carlsbiz
  • 1124 Answers
SOURCE: WE HAVE AN AMCOR ALD 12000E AND THE CONDENSATION
That can be quite normal.. Depending on how much humidity there is in the air..
Posted on Jul 22, 2009
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
Bose p1 turns on but only first touch works then freezes
If you've done the complete walk around i/e--unplug from wall/remove batteries takes bout 1/2-to-1 hour don't be in a hurry then go bac & reset--if no go then your room interfac M-1 needs repair..1boseguy@gmail.com
Apr 16, 2017 | Bose 023795 LCD Touchscreen Remote Control
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Beeps and flashes when I plug in the unit but it will not turn on.
When the unit beeps and the display flashes that means that you need to drain the water. It will not turn on until you drain it. If you have drained the water and it is still doing that then I don't know what's wrong sorry.
Jun 14, 2010 | Amcor PLM-14000E Portable Air Conditioner
My refrigerator beeps 5 times every few minutes and won't stop. The doors are closed. I forgot to turn it back on when I cleaned it yesterday so it was off for about 16 hrs. When I turned it back on, it...
The refrigerator is probably beeping because it is too warm. It has a sensor thaat will make it beep to warn you if it gets too warm. After being off for such a long time it will take a long time to get it cold enough again to stop the beeping. Give it time and it will stop.
Nov 16, 2009 | Electrolux Refrigerators
I have a code 88 -What is the problem has ben 48 hours
This is an added extra and basically a new problem. Mine is brand new. I hold the left button down, and get the first beep, then hold the right button down, and it beeps multiple times, and stayes at 88. It took about 15-20 minutes of trying this before we got the 00. I think the lock mechanism is broken, as I can't get it locked either at the end, so I just let the system lock itself after 1 minute. We unplugged it and tried again, and still after multple time eventually got it to go to 00. I take it that this isn't normal.
Jun 22, 2009 | Intex Automatic Salt Water System for ...
Amcor Ultracool by 12,000 BTU Portable Air Conditioner and Heater  Logo
75 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
