Question about Garmin GPS V Receiver
Screen is blank when powered up - Garmin GPS V Receiver
  • 5 more comments
  • redram Jun 10, 2008
    Turned off ignition when turned back on 5 min. later screen is so faint you have to hold unit at an angle to see a very faint image.
  • Anonymous Jun 26, 2008
    screen flashes black then goes clear on power up.
  • Anonymous Aug 11, 2008
    screen is black when powered
  • bob tam Sep 19, 2008
    I turn on the power switch and I just get lines on the screen. Period.
  • sv1fxe Sep 20, 2008
  • Zcyka Sep 25, 2008
    After powering up and working normally for a varying, but relatively brief, period, the screen goes "clear" except for a thin horizontal (along the long axis of the GPS) line about one pixel wide across the screen. It cannot be shut off when this happens, but must be removed from the source of power.
  • kpaulovic Nov 09, 2008
    Same problem with screen going blank with thin horizontal line across. Changed batteries, cleaned contacts, adjusted tension springs on battery door, tried alternate power (12v) conncetion. Problem still present.
My problem was the unit went into sleep mode Garmin helped me on the phone
Posted on Nov 09, 2008
I power up the unit and after various periods of time, it goes blank except for a thin line across the entire screen. I have changed batteries, readjusted the tension springs in the battery door, checked the plug, etc. Problem still present
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
My laptop shows blank screen lights are on but
be sure no power and all power source is unplug. remove and connect your LCD connector. if not try to change your memory RAM.
Sep 24, 2009 | Dell Inspiron 1150 Notebook
My screen went blank. When I power up, the SANSA
Press menu button for 15 then it turns off .. after that .. turn it on again
Jul 12, 2009 | SanDisk Sansa e260 MP3 Player
Blank screen
The Bestec 250 watt power supply no screen, blank or otherwise. Your problem lies elsewhere.
Jun 30, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
Blank screen
You need to power drain
step1. remove battery and ac adapter for your laptop
step2. HoLD POWER BUTTON for 30secs-1mint
step3. put back battery and ac adapter
step4. power on it sud boot normally
try this hope it helps you
Feb 25, 2009 | HP Pavilion dv6000z Notebook
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
Will not turn on
When holding the power button, to turn on the device, the screen pixelates dark and then goes blank. If I continue to hold the power button the screen will continue to pixelate dark and then go blank. In the end, the device still will not turn on.
Dec 18, 2007 | Garmin GPSMAP 180 GPS Receiver
Garmin GPS V Receiver Logo
269 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
