Question about Frigidaire FAA065M7A Air Conditioner
Air conditioner turns on then shuts itself off immediately
Our air conditioner was running fine all day then our check filter light came on. We shut it off and cleaned the filter. When we put the filter back in and turned the A/C unit back on it will not stay running. The power light is on but it does nothing. It shuts itself off after we turn it on. I can't understand it. It was running fine prior to changing the filter. All we did was pull the filter out and put it back in. HELP Please!!!
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
Blinking Nature Indicator Light
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
Jun 14, 2010 | Samsung AS18A6RB Air Conditioner
Shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
May 17, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioner unit outside, fan not going but air is coming out of the vents. The thermostat is on 50 degrees. If it is shut off for a while and turned back on it will turn on but after and hour it will...
is the fan out side running when you are getting cool air? IF so check the out door coill is it clean, If not the fan could be over heating because it is pulling to hard. you should be able to feel the air 2' above the unit.
Aug 06, 2009 | Goodman CKL24AR24 Air Conditioner
Outside a/c fan quits but compresser still runs
it sounds like the fan is over amping itself and shutting down on thermal overload check the amp draw during running time and compare it to the sticker on the outside panel it should be running .9 amps, and it will over heat if it runs around 1.2 amps or above
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
No spark to ignite
vacuumed out area behind filter--it works fine now.
Dec 18, 2008 | Rinnai EnergySaver 556 Air Conditioner
Unit freezing up and shutting off
Ordinarily air conditioners do this when they are too big,(BTU wise), for the area being cooled. They will shut off to prevent system damage. There has to be enough warm air drawing back to the unit to keep the coils from freezing up. A more rare scenario would be an overcharge from the factory and manifest itself immediately.
Thank you,
Dave E. (Illeagle)
Jun 15, 2008 | Maytag NMPEB08F2A Air Conditioner
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Not turning on again
try cleaning The air filter in your set. It may be a thermal problem due to a clogged air filter.
Jan 19, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Frigidaire FAA065M7A Air Conditioner Logo
7,097 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
