Question about Haier HDN655E Dehumidifier
Tank-Full light keeps flashing
I used my Haier HDN655E dehumidifier once. Unplugged the cord. Emptied the tank. Put the tank back in. Plugged the cord back in and I get a several beeps with the "Tank-Full" light keep flashing.
I had tried the following:
1) According to the manual, it takes 3 minutes for the 'Tank-Full" to disappear and then it will work. I waited for 15+ mintues and I still the same thing, flashing "Tank-Full" light.
2) I pressed the ON button and waited for 15+ minutes and still same thing, flashing "Tank-Full" light.
3) I pressed every button trying to reset. Same thing, flashing "Tank-Full" light.
4) I adjusted the water level latch thingy and same thing, flashing "Tank-Full" light.
5) I took the unit apart (plastic cover). Inspected the components. All appears in brand new shape. (I only used it once.) Reassembled it and same thing, flashing "Tank-Full" light after plugging it again.
  • 883 Answers
SOURCE: HDN655E Haier dehumidifier
when you "...pressed the on switch and it turned on and then turned off and it won't turn back on...", was this done in rapid succession or was some time allowed between switching? if rapidly, the micro inside "locked-out" the keypad for starting, to prevent compressor damage. if not rapidly, then look inside for a possibly a starting relay...did it used to "click"?
Posted on Jun 02, 2007
  • 625 Answers
SOURCE: Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
Posted on Aug 21, 2007
SOURCE: Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Posted on Sep 17, 2007
  • 2712 Answers
SOURCE: Haier Dehumidifier stuck on 45
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Posted on Sep 29, 2008
SOURCE: A year ago we lost the electronics board on the
It was the 125v 12amp pfuse hidden on the bottom of the board under a bluse plastic cover,
Posted on Dec 08, 2009
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Problem with haier hd306 dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
Oct 02, 2009 | Haier HDN655E Dehumidifier
Haier HDN305 Dehumidifier
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Haier HDN655E Dead
Aug 10, 2007 | Haier HDN655E Dehumidifier
No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Sep 19, 2006 | Haier HDN655E Dehumidifier
Does not turn on
All dehumidifiers have an interlock to prevent them from running when the tank is out. This is to avoid a mess with not tank for the water to collect in. I would say that your interlock switch is in a position which is telling the machine that there is no tank in the unit. Take the tank back out and look into the space with a flashlight to find the switch. It could be on the bottom or the top. Your operation manual might be helpful in locating the switch. Once you find the switch check it for operation. It should move or depress when the tank is put in. It probably is jammed and you will have to determine whether it can be fixed or you may need to replace it. If it moves freely then it is probably defective and will need to be replaced. Good luck.
Jul 07, 2006 | Danby DDR451 Dehumidifier
Haier HDN655E Dehumidifier Logo
166 people viewed this question
Top Haier Dehumidifiers Experts
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
