Question about Lexmark JetPrinter X1185 All-In-One InkJet
Printer will not print color
I removed the tape from the bottom of the ink cartridge. I have checked the settings they are set for color prints. Should I reinstall the printer.
  • 44 Answers
Yes remove all of the software and re install. make sure you go through the adjustment settings
Posted on Jun 09, 2008
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Color printing problems
check the in printer settings about printing with color, and also on the pc side make sure its not set to black and white only.
Jun 20, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    New color ink cartridge does not print red. reason?
    Here is my advice:
    Step one: Run the clean print cartridges utility
    1.
    Press the Setup button.
    2.
    Press the down arrow key.
    3.
    Select Clean Print Cartridge and then press OK . The device prints a test page.
    4.
    Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
    5.
    Open the Printer Toolbox . There are two ways to do this:
    Open HP Solution Center , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Features tab, then click the Printer Services button.
    6.
    The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
    Step two: Replace the problem cartridge (you probably have a defective cartridge)
    If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now
    Cause and prevention
    Color mix is usually caused by a material touching the nozzles. Ink can wick along the material and travel from nozzle to nozzle. When different colors of ink mix in this way, the result is muddy, inaccurate colors.
    Missing colors occur when the cartridge nozzles dry out, or when a color is exhausted because of specific printing demands.
    Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it.
    After you have removed the protective tape, do not allow anything to touch the nozzles.
    Print at least once a month to keep the print cartridges in good working order.
    Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges.
    If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector.
    If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up. Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Jul 17, 2010 | HP PSC 2410 All-In-One InkJet Printer
    Re Canon 2600 printer.I recently purchased a black Ink cartridge and replaced the old one. A week later the color cartridge also shows empty even though I hardly use color. Can I not print in greyscale...
    Please follow the instructions below from Cannon support page...
    Setting the Ink Cartridge When printing, you can specify which ink cartridge to use. This is convenient if one of the ink cartridges becomes empty, you can continue printing by specifying the ink cartridge that still has ink. Note:
    • When the following settings are configured, Black Only is disabled. The color ink cartridge is used to print.
    • A type of paper other than Plain Paper is selected for Media Type on the Main tab.
    • Borderless Printing is checked on the Page Setup tab.
    • Canon recommends that you use the ink cartridges installed in the printer and not remove them until the ink runs out.
    You can set the Ink Cartridge Settings from the Maintenance tab in the printer driver.
    To access the printer driver from the application software, click here.
    To access the printer driver from the Printers folder, click here.
    Application Software -
    Note: Depending on the application software, command names or menu names may vary and there may be more steps. For details, refer to the user's manual of the application software.
    1. Select the command you perform printing on the application software in use. In general, select 'Print' on the File menu to open the Print dialog box.
    2. Select your printer model name and click 'Preferences' (or 'Properties'). The printer driver setup window appears.
    3. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
    4. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
    5. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
    6. Click 'OK' on the Ink Cartridge Settings window.
    7. Click 'OK' or the applicable button to print.
    Printers Folder -
    For Windows 7
    • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    1. Click the Maintenance tab. (The Maintenance window opens.)
      Note: The layout varies depending on the printer and version of Windows you are using.
    2. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
    3. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
    4. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
    5. Click 'OK' on the Ink Cartridge Settings window.
    6. On the Printing Preferences window, click 'Apply'.
    Mar 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    New ink cartridges. Printer won't print and does not show the new cartridges.
    1.
    2.
    3.
    4.
    5.
    6.
    Nov 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Tops and bottoms of letters are cut off. I have changed the ink cartridge
    Replace the old ink cartridge.
    Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
    1. Will have Copper-colored contacts.
    2. Plastic tape with pink pull tab ( must be removed before installing ).
    3. Ink nozzles under tape
    4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
    5. Top & Bottom not printing properly.
    6. Load unused, plain, white letter, A4, or legal paper into the input tray
    7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
      1. Press 6 to select Tools .
      2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
      3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
    Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
    Don't know how to install ink
    Installing print cartridges
    1 Open the printer, and then press down on the cartridge carrier levers.
    2 Remove the used print cartridge or cartridges.
    3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
    Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
    4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
    5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
    Removing a used print cartridge
    1 Make sure the printer is on.
    2 Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
    3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
    4 Remove the used print cartridge.
    Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
    Apr 13, 2009 | Lexmark X4650 InkJet Printer
    Printer stopped printing colour
    Are you using Name brand ,new ink cartridges?
    Take the color cartridges out and make sure you removed the tape from the bottom of those cartridges. if done already take a wet paper towel and squeeze out the excess water, then lay the damp paper towel folded in half on a flat surface.
    Then set the colored in cartridges one at a time with the ink side pressing against the damp paper towel for about 3 min. after 3 min you should see the ink drain on to the paper towel if so then replace the cartridge back into the printer and that should solve your problem.
    Feb 14, 2009 | Canon i850 InkJet Photo Printer
    Can't print color
    Just a thought, have you removed the tape on the top of the cartridge which allows the ink to flow, removing the tape allows air to be sucked through the cartridge.
    Another thing you could do, is take all the cartridges out of the machine , remove the printhead from machine, then use a tissue and dab the bottom of the printhead, to see if ink is coming out. If not place ink cartridges on the printhead and place a vacuum cleaner hose on the bottom of the printhead and turn it on, this will force ink through the printhead. Dab Printhead again to see if any ink is there, if not try again. Place back in printer and try printing
    May 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
    Lexmark JetPrinter X1185 All-In-One InkJet Logo
    20 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
