Question about ASUS P4P800-X Pentium Motherboard
Burnt DDR DIMM socket
My motherboard model is an Asus P4P800-X. It has 4 DIMM sockets, two are blue and the other two are black. The order of these sockets is blue, black, blue, black, and their specific names are DIMM A1, DIMM A2, DIMM B1, and DIMM B2 respectively. The problem is, the DIMM A1 socket is burnt and I have 3 others left to use. If one of the sockets are out of commision, is it still possible to use the other 3? Note, I have to use the blue DIMMs first and since one is out of commision, I have a second blue DIMM to use. Is it possible to install a DDR module without having to put it into the first DIMM?
    Genius:
  • 1,601 Answers
You can probably use the other 3. But 1 wont run as DDR.
How did you get it burnt?
Posted on Jun 09, 2008
    Problem Solver:
  • 6 Answers
It may be possible, but the system may very well become unstable at times. The purpose of the different color dimms is either daul band memory and or hypertheading, which means the memory needs to be matched and in pairs to work correctly. I would try one pair in the same colored slots in which one of them is not burnt. Also can you get it to boot with one stick of ram in a slot? Have you seen this board boot at all with 1 burnt slot (Known Good Board). Hope this was informative to you. Good Luck, Let me know how it works out.
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
ASUS P4S533 Motherboard type of ram to add
Your "ASUS P4S533" model motherboard has three DDR SDRAM DIMM sockets.
You can install any DDR DIMMs with 64MB, 128MB, 256MB, 512MB and 1GB into the three DIMM sockets shown in the picture below. Total system memory can be max. 3GB.
You can see the listed qualified DDR333 memory modules in the picture below and use any of them with your motherboard. Also you can check the ASUS website for the updates.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 10, 2010 | ASUS P4S533 Motherboard
Anyone know why an ASUS PTGD1-LA motherboard will only take memory in slots A1 and A1 or A1 and B1 but not anything in B with both in A filled? Brand new memory.
HI,
The board has specific requirements for memory. Here's the Memory Configurations :
  • You may install 256 MB. 512 MB and 1 GB unbuffered non-ECC DRR DIMMs into the DIMM sockets using the memory configurations in this section.
• Installing DDR DIMM. Other than the recommended configurations may cause memory sizing or system boot failure.
• In dual-channel configurations, install only Identical (the same type and size) DDR DIMM pairs for each channel.
• Always install DIMMs with the same CAS Latency. For optimum compatibility , It Is recommended that you obtain memory modules from the same vendor
• Double-sided x 16 modules are not supported on this motherboard.
• Due to chipset resource allocation, the system may detect less than 4 GB system memory when you installed four 1 GB memory modules.
For dual-channel configuration you may:
install identical DIMMs in all four sockets
• install identical DIMM pair in DIMM_A1 and DlMM_B1 (blue sockets) and identical DIMM pair in DIMM_A2 and DIMM_B2 (black sockets)
• install same size DIMMs in DIMM_A1 and DIMM_B1 (blue sockets) and another same size pair in DIMM_A2 aid DIMM_B2 (black sockets)
Hopefully this will help understand how to install the new memory.
Thanks Mark
Mar 19, 2010 | ASUS PTGD1-LA Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
ASUS MOTHERBOARD P4X-X CAN USE ddr 400
pls see ur specs here
http://www.baber.com/motherboards/asus/asus_p4xp-x.htm
ur board only support following RAM specs u cannot use DDR400
Memory
  • 2 x 168-pin SDR DIMM Sockets support max. 2GB PC133/PC100 non-ECC SDRAM memory
  • 2 x 184-pin DDR DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM
pls rate me FIXYA for this help if u like
Mar 13, 2009 | ASUS P4XP-X Motherboard
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
Which GB ram seaport
\ x 184-Pin DIMM Sockets ddrsdram x 184-Pin DIMM Memory Type
DDR Maximum Memory 3 GB
Your board support maximum 3 gb ram with above mentioned details
Regards
Balisonu79
Feb 14, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Strange ram problem: just one socket works
Try cleaning the socket with a small clean paint brush or similar to this... then clean the memory socket-in area with an eraser, best eraser is the black area of RABBIT brand... or Mongol eraser.. Just clean that part and try again...
I hope it works.... Works most on my customers here on my shop.
Jan 30, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800-X Pentium Motherboard Logo
375 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
