Question about IBM ThinkPad T42 Notebook
My ibm thinkpad booting and hanging fault
When i press power ON button it comes on but will not boot, one of the green LED before the battery indicator LED will be ON but the LCD remain black. Sometimes when it tries to boot it hangs after working for 1 minute I have the same problem too. The green LED on the left of the battery indicator (just before it) shows up when I press the power on switch the laptop. When I again press power on, this LED goes off. It repeats the same again and again when power switch is pressed. There is no display at all. When the green LED is on, I can hear that the fan inside the laptop is rotating. When the LED is not on, the fan noise also goes off.
  • Anonymous May 04, 2009
    If I cant connect to an external monitor is there a way to check ? if this is a graphics card problem
  • 458 Answers
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Posted on Jun 09, 2008
In my IBM T23 Thinkpad battery is fully charged showing green light constantly but not able to switch 'ON' after pressing the power button. What should I do?
try to switch it on with power cord still plug in it, if it do boot-up, you have to replace your baterry, if not somethings wrong with your laptop
May 06, 2010 | IBM ThinkPad T23 2647 Notebook
Dead laptop
1.Turn computer off
2. Remove the battery, charger and all accesories connected.
3. Press power button for 1 minute
4. Connect the power adapter only.
5. Turn on the computer.
If not turning on and not even boot to lenovo screen then posible issue with the hardware. call the manufacturer if you are still within warranty they can fix that for free.
Mar 28, 2010 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.
Remove battery and power for a minit, install it again, power up mains and try again. This helpe me here in Paraguay several times.
Saludos Wolfgang
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
System won't boot - show's green battery icon only
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Jul 07, 2009 | IBM ThinkPad T42 Notebook
My IBM Thinkpad T40 2723 will not boot up
The first thing to try is to unplug the power adapter from the computer then remove the battery. Then press down the power on button for a second or two. Put the battery back in and reconnect the power adapter and see if it boots.
Mar 26, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad R40 2897
you can buy ext. hd case to back up your things, if your ibm can't boot then might be your motherboard got problem or graphic card.
Sep 08, 2008 | IBM ThinkPad R40 2897 Notebook
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Mar 30, 2008 | IBM ThinkPad 380ED
IBM ThinkPad T42 Notebook Logo
371 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
