Question about Maytag M6D24E7A Air Conditioner
No cold air
My ac unit gives out small amounts of cold air and I would like to know if there is someway to possibly refill the coolant or any other general suggestions to bring back the cold air
  • 3 Answers
Unless you are EPA Certified you can not charge an air conditioning system with refrigerant. You would need to check with gauges to see the pressures. You would need to find where the leak is. And you would have to buy refrigerant. Does it sound like the compressor is coming on when you turn it on or just the fan? If the compressor isnt coming on it could be a realy or contactor.
Posted on Jun 09, 2008
Chrysler 300m ac only blows cold air out the defrost vents
That is what the AC is supposed to do blow cold air .
If you are trying to use the heater check all of the settings first make sure their correctly set .
Then take a look at your antifreeze test it you can have it done or you can buy a little tester ware you draw out a small amount of antifreeze and see how the little balls in it float compared to the gauge .This will tell you if the coolant is good or bad ..
If the coolant is bad you need to look at your heater core if its clogged you will get no heat but if the AC is feed from a different source into the same duct the accuator witch is a control valve for the duct eight vacuum or electric control .
You gave little information in your question so this is the best answer I can give you .
Aug 01, 2016 | Chrysler Cars & Trucks
AC not giving cold air
Kindly check outdoor unit fan Motor running or not . and it may possible blockage in the copper tubes (/capillary)/.need to internal clean by nitrogen flushing.
Jul 26, 2016 | Carrier Heating & Cooling
How to refill ac coolant.the unit is not blowing cold air
get a can of quick recharge with the hose and read directions
Jul 26, 2015 | AC Cars & Trucks
Can the freon be refilled in window units?
A refill needs to be done by a technician who has the gauges to refill it.
Jun 23, 2015 | Heating & Cooling
Air conditioner blows cold except at a low idle
Sounds like your AC system is low on coolant. Higher rpm will pump enough to cool but at low rpm low ststem will not cool. You need to go to someone who services AC systems or if you are a DIY person buy a refill kit at an auto parts store or a store with an automotive section.
Note you will be to be familar with servicing AC and be able to locate the site class and know the type of coolant you need if you have an older vehicle.
May 25, 2012 | Jeep 2004 Grand Cherokee Laredo
When I turn on the AC warm air blows through and never changes unless it's cold outside. Do I need to fiil or replace something?
Most probably just needs to have the AC serviced and refilled with coolant. Since the car is a '95. I had to bring in my to get the coolant refilled just a few weeks back and it is a 2004. We used to just call it a freon refill, but they don't use normal freon anymore, they use a coolant/refrigerant that is safer for the environment, but this doesn't matter for you. Just bring it in to your mechanic or to your dealer and have the AC serviced.
They should probably put in a dye as well to see if there is a coolant leak, If so, it is usually a very slow leak and repairing the whole AC unit wouldn't be worth it. Either way, it needs a fill.
Aug 17, 2010 | 1995 Volvo 960
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
Ac blows cool but not cold
Type and model helps but you probably only need it recharged. Depending on whether it is a whole-house unit or hangign in a window, it will cost from $50-$120 to refill lost coolant.
Aug 07, 2009 | Heating & Cooling
1995 Honda Civic-AC only blows cool air
the reason it's getting warmer is most likely due to a slow leak. it need the proper amount to be cool. less or more and it will be warm. it's also possible when it was charged he added too much or not enough. also if air is in the system (from not vacuuming the system or in the refrigerant tank) it will not cool as well.
the car need to be recovered, vacuumed (checked for leaks), refilled after purging the refrigerant tank of air.
Jun 24, 2009 | 1995 Honda Civic
No cold air. Unit runs fine.
yes if it has service ports but if it lee=aked out you need to fix leak first
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Maytag M6D24E7A Air Conditioner Logo
150 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
