Question about Kenwood -TK2100-2140-2160-2200-3100-3130-3131-3140-3160-3200-260-270-272-360-370-372-373 Comp... 2-Way Radio
R-600 with SSB problem
The receiver has undergone some servicing, due to PLL disengagement. This solved therev appears a new problem. When the USB is correct on the audio pitch the LSB is not. Where's the problem and how to solve this?
    Brigadier General:
  • 6,966 Answers
It is perplexing that only the alignment of the lower side band would be affected by the PLL repair/replacement. The output of the PLL/VCO is common to both the USB and LSB and the problem would be on both. In any case, what perhaps is required is alignment (internal tuning) of the LSB side. However, often, there would be multiple steps in performing said alignment (and in some cases, need for an RF with/and an audio signal generator). Having said that, perhaps your best bet would be to make use of the detailed procedures as outlined in a service manual. Unfortunately, they are not as readily available as user's manual (freeware). Some available (for a fee) may be found here, here, here or here. Pls confirm with the possible source contents to include detailed alignment procedure.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 09, 2008
Cobra 1000 will not receive or transmit.
Sounds like a problem with the VCO / PLL Circuit since nothing happens in RX or TX. Check to make sure you have the correct supply voltages to start with and also check to see if you have 10.240Mhz. Use the service manual and go through the PLL/VCO alignment section. If anything is missing then you at least know where to look.
Apr 30, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cannot select USB or SSB.Displays LSB or LISB? Very poor reception
On the Satellit 750 you have a button marked SSB. If you have selected a shortwave band then you can press the SSB button. Pressing the button repeatedly will toggle between LSB and USB.
You will need to know the exact frequency and the broadcast time, and the side band. Turn the radio on. Select a frequency which you know carries SSB signal and wait. Those that broadcast on SSB are not radio stations, maybe ham radio operators.
You can also select a short wave band, press the SSB button once or twice to select the side band and launch the automatic tuning system. It will scan the meter band and stop for a few second when it receives a strong enough signal. If you are able to perceive a clear signal on LSB or USB then you found a broadcaster. Some radios just have SSB and you cannot choose the side.
Personally, when I buy a radio I always insist on SSB but I have never been lucky tuning in an SSB signal. I keep trying once in while.
Jun 23, 2011 | Grundig Satellit 800 AM/FM/SW Radio
What is a digital pll fm modulator
Hello towturtle,
An FM modulator is a little box that plugs into your receiver antenna connection. It sends a low-level signal directly to the radio which you then tune in on the FM band just like a radio station. They're handy for older receivers that do not have AUX, USB, or iPod inputs. You plug your device into the modulator and it plays through the receiver. The "PLL" just means that the tuning uses a technology called "phased lock loop" which keeps the frequency from drifting.
Hope this helps.
Oct 14, 2009 | Car Audio & Video
No cb channels no audio no recive
If you have no channel display or CB operation, it sounds like a blown voltage regulator that supplies power to the CB PLL circuit.
Sep 14, 2008 | Ranger TR-696F SSB CB Radio
Cobra 2000 gtl
cobra 2000
am carrier 4.4 volts will not ajust...ssb carrier will 3.5 volt will ajust but max out put is only 3.5 volts.losses all voltage at ssd carrier when switched to usd r lsb
Jul 03, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
42PF7320A/37
Regards
Has already received a question for the Philips plasma television from yrush member had asked about the location of damaged Crystal View I should send him service Manuel If he wants
With greetings ------------------------------------------------------------------------------------------
Symptom
TV turns "off" by itself, the LED blinks 5 times. Cure
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397). REMARKS:
- Error 5: Viper does not boot.
- Only a "reboot" is visible in the Debug menu.
- Error will appear after heating up of the xtal. HISTORY:
23-03-'06: Chassis added. Text updated. yassur
Jun 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
SSB ALIGNMENT
You'll need to connect Frequency Counter to C252 & adjust:
USB Frequency: 10.6975Mhz adjust L126 in receive mode
LSB Frequency: 10.6925Mhz adjust L127 in receive mode
May 04, 2008 | Magnum DeltaForce CB Radio
Cobrba 148 gtl TX
Thanks sharcnet i just going through the steps in my head trying to figure out what I would do if it was on my bench ..Between the two of us we'll figure it out!!!..... Dean
Feb 01, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
President mckinly ssb/am model with mb8719 pll chip.
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
Jul 31, 2007 | Cobra 19 DX III 40-Channels Base CB Radio
Radio Communications Logo
106 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
