Question about Samsung HCL5515W 55" Rear Projection Television
Samsung HCL5515WX/XAA convergence Issue
Quick Question. When I removed the AA95-00705A PCB Sub board with the convergence circuits on it, I found that the 100K Variable resistor is fried. As I am having issues with Red convergence, could this be the only issue or do you recommend replacing the STK392-040's as well? What about the 150 Ohm R's at RFZ19 and higher?
  • erauee Jun 11, 2008
    Thank you for the information. I was able to get some STK392-040's from electronix Corporation online for about $10 each. Surgery commences tomorrow. We'll see what happens.
    Also, if anyone is interested, I am now the proud owner of the Service Manual for the Samsung HCL5515WX/XAA. If anyone needs a copy, contact me.
  • edsel ranger Aug 24, 2008
    convergence off, red wavey, corners bowed colors move but won't converge, all colors sharp and clear. Two convergence power modules and one fried resistor replaced (modules on heat sinks on video board) problem persists. tech who replaced items at it not very helpful when problem remained. Prior to replacements blue would not move at all, now all colors move but again no convergence.
  • Samsung Master
  • 8,617 Answers
I would replace both of the STK392-040, and check the resistors with one side out of circuit. The variable resistors are melted at the factory after the resistance is dialed in. I would check the resistance on it before replacing it. You can get replacement ICs and resistors at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Posted on Jun 10, 2008
  • Sonny Berry
    Sonny Berry Jun 11, 2008
    best wishes on your repairs. Just a small word of caution , be wary of any convergence IC that sells that cheap as youre not getting real sanyos so they wont last as long as they should.
Samsung rs265tdbp refrigerator is iced up and freezer works fine. is it the defrost heater or defrost control?
Hello Marc-Ryan Digesu,
You have given this some thought... Very impressive!!
It can be only three things (barring physical wiring damage):
YES... Highly likely it is the CONTROL BOARD
Looking into your model (but you MUST verify the DA41 00670 NUMBER yourself)...
(3 basic parts of your DEFROST CIRCUIT)
- heater(s)... very unlikely
- defrost thermostat... unlikely
- clock/timer or control board... most likely (easiest)
The first thing you want to do (after removing power)
BUT before REMOVING ANYTHING...
take LOTS of USEABLE pictures. You will need to put every wire & screw exactly back EXACTLY from where it came!!
Always ground your hands before touching any circuit board you VALUE (BETTER purchase an anti-static wrist band... below).
Look at the bottom of the board for any obvious solder issues...
Else.. order that spare board you always wanted (anyway).
Always get three estimates... (about $115)
Prices may vary but the parts are ALL THE SAME.
Hope this helps... I like refrigerators... feel free to comment me back if want to discuss...
(I have a spare board & door gaskets... because I plan on KEEPING my refrigerator (until that HOT PLACE freezes)).
Even on eBay
Samsung DA41 00670C Assy PCB Main Main Control Board for RS265TDWP XAA OEM
Also at appliancepartspros:
http://www.appliancepartspros.com/samsung-assy-pcb-main-da41-00670c-ap4700476.html
Sears
Refrigerator Electronic
Control Board Part Number DA41 00670C SAME DAY...
partsselect.com
PartSelect Appliance Parts and Repair Help
Jun 01, 2016 | Samsung Refrigerators
Another Question Please.
Horizontal lines can be cause by many things. One of which is the convergence module. $130.00 is a little high for something that can be caused by other things as well.
Jun 17, 2007 | Samsung PCN5425R 54" Rear Projection...
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
Samsung PCL5415RX/XAA has red lines and ghost effect
TAKE SOME ADVICE:
Lots of people try to buy a "board" for this kind of repair and it is a mistake.
If you have a convergence problem just get someone to replace the two STK-392-040 convergence chips this set uses.
Yes, there are two fuses near them that need to be checked--you can get all (both chips and the fuses) on EBAY for less than 20 dollars.
A replacement board will be more and I have seen several people who suddenly had new problems who did this.
Replacing the board sounds better but usually is not.
This set is not the most easy to work on but replacing the BAD parts is as easy as changing a board.
If you need to know--there is a seller I use on EBAY WITH THESE CHIPS.
These sets are not like the Plasma sets where they only sell circuit boards--with this kind of set you are almost always better to fix the board you have.
If you need any help do not hesitate to ask--I am here to help.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Samsung PCL541R 54" Rear Projection...
I have a HCL473W with a 'concave' screen effect on 2 colors??
You don't need to replace the whole board, regardless of which board it may be mounted on. The STK IC convergence chips alone are all that need to be replaced. You can order them from a number of different online sites. You can try Alibaba.com. If you have any more questions, feel free to ask!
Nov 08, 2009 | Samsung HCL473W 47" Rear Projection...
I was just given a samsung hcp4752wx/xaa. The
OK, Its always best to replace the lens assembly if its not preforming well. never dump the fluid. just replace the lens. As for the double images and the misalignment of the blue convergence line, this is caused by a faulty convergence chip that is located on the convergence board. you will need to replace this board in order to restore proper convergence performance.
May 16, 2009 | Samsung Televison & Video
Convergence circuit correction
BEWARE some people suggest that the IC's can be replaced and that they are part of the convergence circuit, they are on the POWER board for the convergence circuit, the convergence is a separate 'card' that is almost the same price as the 'sub board' with the IC's. Although most people favor the sub board as the culprit.
Jan 21, 2009 | Samsung HCL473W 47" Rear Projection...
Samsung HCL5515WX
i have it in pdf form do you still need it?
Nov 17, 2008 | Samsung HCL5515W 55" Rear Projection...
RGB COLOR PROBLEM.
You will need to check the plus and the minus convergence voltages in the main power supply. There are a couple of circuit protector fuses that go bad. Do not replace these untill you replace the convergence IC's or you will cause more problems in the main power supply. Good Luck
Apr 22, 2008 | Samsung HCM653W 65" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL5515W 55" Rear Projection Television Logo
198 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
