Question about Compaq Computers & Internet
Compaq Presario F700 Acts like it is starting to boot up hen pwered on, but then shows a message that sys was not shut down properly etc.. I have tried all the safe modes as well as regular mode. The screen has stopped at crcdisk.sys and then goes blank and stays there forever until I do a hard power down.
    Scholar:
  • 187 Answers
Boot into the recovery console and run; chkdsk /r Note the space between dsk and /r. If you are unsure of how to get into the recovery console, and have access to a Windows CD; 1. Boot the computer with the Windows CD 2. Select the option to enter the recovery console 3. At the prompt, type CHKDSK /R and press enter (this may take a while). If you do not have access to a Windows CD, but DO have access to a working system with a CD-R or CD/RW, download the XP Recovery Console CD ISO* and burn it to CD using DeepBurner (or whichever application you have that supports such (DeepBurner, Nero, MagicISO etc)). http://archives.mysteryfcm.co.uk/?f=System/Diagnostics/XP_Recovery_Console_CD_ISO * This CD ISO will load pretty much the same as the XP installation program but will NOT provide installation options, ONLY the recovery console. This can be used regardless of whether you are using 2000, XP, 2003 or Vista. Once you have the ISO burnt, boot the computer using the CD and go to the recovery console. Once at the recovery console, type the following and press enter; CHKDSK /R
Posted on Jun 09, 2008
My HP Presario F700 recently started showing a recource conflict on motherboard while starting up. In addition the DVD-drive is not recognized even it does a self test. Any idea?
there might be 2 problems that come first in mind
1: due to long time pc explotation bios battery died
2: bios reseted and all divices become masters
firs test battery voltage ir its good try to change bios boot up log
Jul 29, 2014 | HP Compaq Presario F500 F700 and G6000...
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
David
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
How do i reset my computer to factory settings. its a compaq presario f700
Hi!
To restore your Compaq Presario PC f700: Turn the computer on, then while restarting, Press and hold the F11 key. Under HP Recovery Manager, select the option to perform a system recovery. ***Note*** Doing this will delete everything that are save in your computer. Back up your files before doing this.
Hope this can help.
Jul 24, 2011 | Compaq Presario Notebook
Windows Did Not Shut Down Properly PC Wont Boot
sounds like you have a boot sector virus, if you have a Win98SE start up disk you can boot to it then first try running scandisk on drive
Feb 10, 2010 | Computers & Internet
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario F700 wont boot
I had the same black screen problem with my Compaq Presario f700.
I went to the HP website to troubleshoot and found that a hard reset fixes the blank screen issue.
To perform a Hard Reset, unplug the AC power adapter and remove the battery, and then press and hold down the Power button for about 6 seconds. This will drain any residual charge in the capacitors and reset the power management controls to their default condition.
This fixed my problem.
I hope it helps you.
Best regards!
Dec 12, 2008 | Computers & Internet
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
336 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
