Question about Frigidaire FGF326AS Gas Kitchen Range
Oven top burners r fine the oven will not lite the igniter glows but no gas what part do i need. the 3203459
  • 413 Answers
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. (It's the igniter that actually controls the gas valve) The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on Jun 09, 2008
Need to turn gas pilot on
Stove in ? has electronic pilot so there is nothing to turn on
top burners should have spark and oven has a glow
if the burners not lite do you here a clicking sound no clicking spark box is bad
oven not lite need glow
price of glow $40 price of spark box $60
Nov 02, 2014 | Hotpoint Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
Apr 22, 2011 | Viking 27" Professional Select Built-in...
Ignitor lights up bright, but no ignition,no flame and I don't hear the gas turn on like I normally do. Top burners work fine.
Hello, welcome to fixya ! Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven won't lite. Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, 1) need to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2) ignite the fuel once said gas valve is open. A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not lite at all ) but yet not reach the needed value to open the gas valve/safety valve consistently nor adequately, hence the need to replace the ignitor. Try this and I'm certain you'll be up & running and as they say " cookin' with gas" ! I'd suggest you should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 and it will work in your Whirlpool too. Try places like,, etc. Thank's for visiting "fixya" for your stove inquiries. Please take a moment while here to rate the solution provided or let me know if you require further assistance and good luck. macmarkus :)
May 23, 2010 | Whirlpool AKZ159IX Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Model MGR4452BDB range top burners work but oven
    The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
    Nov 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
    Oven wont light
    Gas or Electric? If Gas at the bottom of oven where Oven burner is there is a glow plug ,or some might call ignitor. When it get a signal to ignite gas that glow plug gets hot and ignites gas. and that does goes Bad .
    Oct 10, 2009 | Imperial Commercial Cooking Equipment...
    Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
    The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
    Aug 27, 2009 | Ovens
    Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
    Apr 25, 2009 | Ovens
    GE gas stove the burners on top work, the oven won't get hot
    The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
    Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
    Frigidaire FGF326AS Gas Kitchen Range Logo
    152 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
