Radiator side of engine block lower
Testimonial: "thanks fast response "
Not sure which engine you have, but most of them are on the lower front of the engine as in this diagram. Please see my tip at http://www.fixya.com/cars/r5973094-starter_replace for more info. These are generic instructions. Note, for your car you may need to remove the flywheel cover to get the starter out. If you get stuck or need specific instructions for your car, please get back to me. I will paste instructions from autozone.com below. 3.4L (VIN E) Engine
REMOVAL & INSTALLATION
3.1L, 3.4L (VIN X) and 3.8L Engines
WARNING
Remember that the positive battery cable to the starter motor is electrically "hot" all the time. You must open the circuit by disconnecting the negative battery cable before servicing the starter motor.
To install:
WARNING
To install:
CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes
To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE
IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE
RUNS.============
For
your help there are few relatively help links showing how to remove and install
starter with proper instructions:-----
These
help links will help.
Click
the link below:-----
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn
SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
• Oldsmobile
starter solenoid replacement procedure?...
• How
to replace Oldsmobile starter moor?
• Oldsmobile
starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These
details will help.
Thanks.
RUNS.============
For
These
Click
How to test
starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test cars
starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to replace
starter in car?
How to replace Starter on
Infiniti Q45?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
2006 GM Montana: How to replace Starter
Solenoid?
Saturn SL2: How to replace
Starter Motor?
Saturn
• Oldsmobile
• How
• Oldsmobile
These
details will help.
Thanks.
Saturn SL2 Starter Wiring Diagram?
Oldsmobile starter solenoid replacement procedure?...
How to replace Oldsmobile starter moor?
Oldsmobile starter motor testing?
------------These details will help.Thanks.
