Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Will not turn on
My tv will not turn on. the stand by lights blinks but it will not turn on. in researching i see that this is a very common problem.
    Genius:
  • 2,035 Answers
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Posted on Jun 09, 2008
SOURCE:
Power wontcome on
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX ... 1. soft reset - is just turning tv off & back on 2. hard reset - unplug power to tv for 1 minute then connect power to your Flat-Screen
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding ... I get a center led light when its plugged in showing power. ... I have a dynex 42 in and it dose not have stand by but turning on on the light but nothing happens ....Repairing Flat Screen TV - Blacked out with blinking red light ...
i have a 32" rca rlded3258a tv. The red light in the bottom ...
Dec 09, 2015 | Televison & Video
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
My tv is no working stand by light and bulb
Without doing alot of research I see that you have a dlp TV. If the light for the lamp is blinking and your unit is 6 years old or older you should replace the lamp. It is definitely bad. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will walk you through it. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 25, 2010 | Samsung HL-S5086W 50" HDTV
The TV will not turn on. Stand by/Timer light just blinks...
well it's due to ur cable connection is unable to receive or ur dish tv
Mar 28, 2010 | Sony KV-35V68 35" TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Mar 16, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
TV wont come on
One of the tubes are gone. You need to replace one. The easiest way is to disconnect the board from the tube. power it on and if the correct tube is disconnected, the TV will turn stay on. Research the problem a bit. This is a common problem
Jan 06, 2009 | Toshiba 51H84 51" Rear Projection...
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
