Question about Dell 962 Photo All-In-One InkJet Printer
I can't install my printer..
I do all the process of intalation, but when it ends, the computer don't have nothing about printers...
    Problem Solver:
  • 6 Answers
What OS do you have?? If Vista be sure you have Vista Driver. Have you tried going into the printer section and try adding a printer and send it to the printer drivers section when it asked for them. Also see if the Printer Spooler Service is turned on in Services section under the Administrative tools section. You could also have spyware blocking the printer or a program such as spybot S&D or a firewall blocking it. Check these while you looking if you haven't already. Good luck, let me know if I was of some help. Thanks Jimmyriggs
Posted on Jun 09, 2008
Usb connectivity problems between packard bell computer and hp c4580 printer- help please!!!
Dis connect printer,go to control panel,un install/remove installed drivers. In my computer properties,go to device manger check USB controller, if found printer device, un install it. restart the system,run driver CD, connect printer USB cable when system searching for the device,check for the printer recognition, do rest installation process..
Aug 19, 2012 | HP Photosmart C4580 All-in-One InkJet...
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
5610 I don't have the the Solution Center and Imaging Tool
Before doing this process ensure that you should have original driver CD with you.. Un plug the USB cable, un install the drivers, restart the system run the CD when it request to connect the printer connect the printer, run the next process till end.. then check.. Best of luck..
Sep 11, 2011 | HP Officejet 5610 All-In-One InkJet...
HI i HAVE LOST THE INTALLATION DISK FOR MY LEXMARK Z1420 PRINTER HOW CAN I INSTALL IT ONTO MY COMPUTER
Simple. Go to the Lexmark web site and download the drivers for your operating system there. They have drivers for almost every model they ever made. if not, search a web site called Driverguide.com
The normal routine for installation is: Unplug the printer before you boot up your PC. Download and install the drivers. Then you connect the printer. [It may even prompt you to do so during the process] This will only work with a USB connection. If you use a parallel cable you will have to shut down, connect cable and reboot. The computer should do a "New Hardware Found" routine and install the drivers at that point. Working in Microsoft Windows of course. If you use Linux or Mac, you will need more information that I don't have. Good luck!
Oct 03, 2009 | Lexmark Z1420 Printer
Software appears to not install completely on my laptop. When I open the AIO Center all icons are grayed out and printer showing disconnected. This printer is also intalled on my desktop. Had a little...
I had trouble installing this from the installer on the desktop. It would quit the process before being done.
I solved this by coping to an available hard drive the installer, and when running the installer from another hard drive it installed fine.
Jun 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Battling between KODAK AIO 7 vs Dell wireless laptop.
try this
  1. Open the Printers folder:
  2. XP Operating System: Select Start > Settings > Printers and Faxes.
  • VISTA Operating System: Select Start > Control Panel > Printers.
  1. Delete all ESP 7 and ESP 9 printers from the folder. The printers are listed as "KodakESP7+xxxx" or "KodakESP9+xxxx", where xxxx can be any number.
  2. Close the Printers folder.
  3. Press Ctrl + Alt + Delete on your computer keyboard, then select Task Manager.
  4. Select the Processes tab.
  5. Stop each of the following processes. For each process, click the process, then click End Process.
  6. AiOHomeCenter.exe
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
  1. Power cycle the printer. (Press the power button to turn off the printer. Wait approximately 30 seconds, then press the power button to turn on the printer.)
  2. Open the home center software.
  3. Click Install Kodak Printer in the bottom right corner of the home center to add your all-in-one printer to your computer.
let me know if this worked or not.......
May 15, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Hp3920 not print
check if you print in A4 format in your printer settings.(default is letter)
Jan 24, 2009 | HP DeskJet 3650 InkJet Printer
It wont print
I don't know why it is, but, so many of the printer problems I answer have to do with original install cd being corrupted(it may have to with mass production process) anyway, you can try this:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 14, 2008 | Xerox WorkCentre XD102 Printer
Trouble with installing software for PCI FLASH Memory Dell All-in-one
First uninstall the Lexmark and unplug it from your system. Next, do a SHUT DOWN. Turn on your system, load the CD, go through the installation process, then plug in your Lexmark.
Jul 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
