Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv willnot turn on
The red light blinks but it will not power up
    Genius:
  • 2,035 Answers
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Posted on Jun 09, 2008
SOURCE:
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Willnot turn manually or by remote on all i get is a red light
The red light indicates that power is getting to the TV. You may have had failure of a fuse, a relay, or the power supply
Nov 26, 2012 | Televison & Video
Hi MY TV HAS NO PICTURE OR SOUND, AND IT WAS FLASHING RED WHEN TURNED ON, BUT NOW IT WILLNOT EVEN GO ON AND I COULD NOT HEAR THE FANS ON EITHER, PLEASE HELP
Follow the money or this case the voltage--follow power cord into the set and to the power supply board--there will be a fuse there---extremely unusual for there not to be blinking lights if the set does not turn on---
May 28, 2012 | Sony KDS-60A2000 60" HDTV
My samsung plasma hdtv willnot turn on the red lite blinks steadily but the tv won't turn on i've only had this tv for 2yrs.
Try pluggng in an additional source (PC, HDMI, DVD player). When you power it on press the source button to see if one switches on. If it does work, pull up the menu and change your input options.
Mar 12, 2011 | Televison & Video
Sharp 42
You either have broken power board or main board. Power board - blinking 2 per second, main board 3 times per second. In an case it has to be fixed by a technician.
Sep 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Red blinking led
My 42" Philips LCD did the same red blinking sequence last night. All was seemingly fine after unplugging it for a bit. An online search, though, has me worried that this may be the start of (potentially fatal) power supply issues. Anyone have a clue what that sequence means?
I've got one week left on my 1yr waranty, so I'm a bit concerned! :(
Thanks!
Jan 15, 2008 | Philips 32PF7320A 32 in. LCD Television
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
322 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
