Question about Ruud Central System Air Conditioner
Breaker keeps tripping
My air conditioner stopped working yesterday. I went to check the circuit break case and saw that the one for the air conditioner was tripped. I switched it all the way to the off position then back to the on position. I turned on t
  • jccclimer Jun 09, 2008
  • 40 Answers
If breaker won't hold compressor is not going bad it is. A simple way to chech your breaker: Make sure breaker is off. Turn power off at outside disconnect. Disconnect the high voltage leads from the incoming at the contactor. Wire nut them. Turn the breaker back on. If it stays engaged you know its not the breaker and you confirm it is the compressor....
Posted on Jul 03, 2008
  • 3 Answers
Your compressor could be going bad. You would need to check to amp draw on the the leads coming out of the compressor. There is a maximum rating listed on data plate. Something simple could be that your condenser the out side part of the unit is dirty. All you have to do is turn off the shut off switch out side, get a hose and some dish soap and wash the coils. Be careful with the water presssure not to bend the fins. Or some thing even a lot of techs look over is the breaker is bad.
Posted on Jun 09, 2008
Could this keep the air conditioner running and trip the breaker
Air conditioner may draw high current. It may trip the cirucuit breaker. You may check the current rating of the air conditioner. If it is higher than the circuit breaker rating, it surely will trip. If it is close but lower, it may trip as there may be other appliances connected.
Sep 27, 2015 | Heating & Cooling
Is there a fuse or breaker on a Panasonic CW1803SU Air Conditioner?
If there's no power up on the unit, you can check your breaker switch box to see if there's any tripped breaker switch. If so, turn it off, and turn it back on. In some cases a sub-panel is installed somewhere else to provide power to the unit. Normally that's where the breaker switch will be in that scenario. If after doing that it keeps on tripping it, or it just won't power up, then you might have some electrical components inside the unit that might be damaged, like a capacitor, or the compressor itself. Sometimes when the compressor breaks it stops turning and overheats, causing other parts to burn also. To fix this you will need to call a professional.
Jul 07, 2014 | Panasonic Heating & Cooling
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
My Maytag Portable Air Conditioner Model #M6P09S2B keeps popping my breaker. Can you help me solve this problem?
This can because by a couple of things. An electrical fault within the AV Unit or the electrical circuit the unit is plugged into has other electric appliances on the same circuit. Thereby, overloading that one circuit. Try plugging the unit into another outlet that is on a different circuit. If it trips a circuit breaker then, the problem is within the unit. In which case, you will need to have the unit checked and serviced.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Maytag M6P09S2B Portable Air Conditioner
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
Circuit breaker tripping from the air conditioner
moter or compresser pulling to many amps on start up you can purchase a hard start kit and also you can ohm out blower moter you could also have a direct short althoug not likly
Aug 09, 2009 | Dometic 57915531 Air Conditioner
Furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Ruud Central System Air Conditioner Logo
2,034 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
