Question about Amana NAV5800A Top Load Washer
Cold water dripping from input
The shut off is not fully working. I have a constant drip into the tub from the cold water input. It fills up the tub in about 24 hours. Is this a simple seal problem, are special tools or parts needed to fix? Thanks
  • 246 Answers
It (unlikely) could be a forign voltage causing your problem. Just unplug the machine and verify the problem continues. Assuming that it does, you likely have debris inside your inlet valve. Since it not servicable, it would need to be replaced. To do this, unplug the unit. Using a putty knife or small flat blad screw driver, push on the 2 clips where the top of the washer meet the front panel while lifting the top. (a flash light will help you see these) The valve is usually held on be 1/4 or 5/16 screws. A replacement valve can be purchased from a local appliance parts store or on line from the manufacture.
Posted on Jun 16, 2008
My washer is leaking into the drum from the fill spout. Just a slow drip (about 1 drop every 5 seconds). There is about 2 inches of water in the tub. How do I stop this leak?
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If it's cold fill only it's clear which one!!
If is only happens when there is power on it could be the PCB malfunctioning and will require checking by the service call.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 04, 2011 | Roper RAX4233PQ Top Load Washer
I do not have a 'drip' but a constant flow,volume
I take it it is a shower only, no tub fill? Is it a single handle or two? Either way, shut off the water, pull off the handle(s), pull out the cartridge or valve, take it to the store and match it up, replace the faulty seals, springs, o-rings, you should be all set. Single handles are a bit more tricky. Hope this helps.
May 28, 2011 | Home
After wash cycle is finished I lift the tub lid and water is dripping into tub.
You may be looking at residual water dripping down from the rim. If the drip is located near where the water fills from, then you may have a water valve (could be either hot or cold side) that is not able to close completely. The valves are typically replaced, but sometimes cleaning can help for short term. Consult your user manual for removal / replacement instructions.
Aug 18, 2010 | Maytag Washing Machines
Ken: maytag washer constantly dripping cold water in tub
Pull the hose and clamps off the cold water inlet valve inside the machine and check for debris buildup. If there's debris from the water line, it may keep the valve from closing all the way.
Dec 02, 2009 | Maytag Washing Machines
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Water drip
There is a water fill valve that allows water in, mixes cold and hot water or shuts it off. Its location is where the hot and cold water hoses connect to the washer.
Get the model number off the machine and go to the web site below and you can see the valve and also the cost of the valve should you choose to fix it.
http://www.appliancepartspros.com/partsearch/
Good luck, let me know.
Regards,
Jul 31, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water Dripping
you need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
LSR8233JQ washer water drips into tub from fill port
Yes the fill valve has been damaged by the silt. If you remove the hoses from the valve you will probably notice that there is either one or both steel screens missing from valve body. You cant remove the screens if they get clogged.
Jan 19, 2008 | Whirlpool LSR8233J
Amana NAV5800A Top Load Washer Logo
35 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
