Troubleshooting my television has no power.
  • 4 more comments
  • dhirsch Aug 10, 2008
    WHen I try to turn my television on, the red light blinks a few times and then it just switches off
  • specialplc Sep 25, 2008
    I turn on power, it blinks, turns off and then it is in standby mode. What do I do??
  • cadzeuba Dec 09, 2008
    I can not turn it on. When I press the power button, there is an audible sound as if I turned on the TV, then it makes the same sound as if I turned it off, and then the standby light blinks 5 times, then pauses for a few seconds, then repeats.
  • Anonymous Jan 31, 2009
    i have the same problem with my sony 32in
  • Anonymous Feb 05, 2009
    FRUSTRATING!!!! same thing...the light that blinks says something about sleep/stand by and so it has been off for a week
  • coopercjm30 Feb 16, 2009
    I turn the power button on and the green light appears then it blinks several times and the red light re appears.. What do I do?
I cant even turn the tv on it has no juice at all. i checked the power outlets and all and nothin is helping what do i do.
Posted on Nov 23, 2008
My power supply does not give output. please guide me on troubleshooting
does transformer get AC voltage on secondary coils
Does bridging diodes get DC voltage coming out
Does voltage regulator chips have DC voltage coming out
Suggest google tv model with troubleshooting power supply video
do this on you tube www.youtube.com
search {your tv model number} troubleshooting power supply
Nov 01, 2016 | Televison & Video
Screen went blank while still on. unplugged power cord and when I plugged it back in the power on light went green. Problem remains
Resolution:
Follow the steps below to troubleshoot this issue.
Verify that the AC power cord is connected securely to a working wall outlet.
Unplug the power cord of the television from the AC outlet.
Let the television remain without power for 1 minute.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
NOTES:
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required.
Make a note of the STANDBY or TIMER flash pattern when referring the television to service.
Aug 13, 2008 | Televison & Video
Troubleshooting a power board and main board in sony television.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 20, 2016 | Sony Televison & Video
Last evening, my television puffed smoke then stopped working
Deffective power supply its a major repair,Theres a shorted parts in power supply.Need for repair technician.Who knows and troubleshoot the power supply.
Jul 11, 2011 | Funai F42PDME 42 in. Plasma Television
My power light is not comming on
I have a troubleshooting tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which explains in detail to the novice how to do basic troubleshooting on any television. Let me know if you need any more help. Thanks for using FixYa and for the generous rating.
hardrocko
Apr 03, 2010 | Televison & Video
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
RCA 52 in television
You will first have to see if cp150 is puffed up on top then go from there! Also you need to resolder all pinns on FBT poor connections on alot of these sets.HAPPY NEW YEAR!
Dec 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba TN 50V71.
the start up or standby power is in need of troubleshooting. I would start by checking the regulator and horizontal output transistors.
Mar 14, 2008 | Toshiba TZ50V51 50" Rear Projection...
Fix my tv
COULD BE FANS NOT WORKING. TAKE BACK OFF AND SEE IF TURNING, CLEAN THEM, OR TURN STAND BY MODE OFF OR GO TO SONY.COM, TROUBLESHOOTING OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Dec 19, 2007 | Sony KV-32S42 32" TV
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
