Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Bissell 7920 proheat
I have changed the belt and now the brush only spins with handle in upright position.
    President:
  • 1,673 Answers
Sounds like you didn't get the ends of the brush roll in the slot, where the red piece goes, there is a slot for the end of the end cap to fit into,
Posted on Sep 15, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I change the belt on the Bissell Proheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm
Mar 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Water/solution flow problem
check your belts. if your brush is not spinning when you have it on, it is a belt. goto bissell.com and there you will find on line videos to help you with this troubleshooting process, it will also tell you how to change it.
May 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Change belt on 7920
heatman101
cvzncbn
Mar 29, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 doesnt spray liquid
Ive oredered the pump belt and brush. after receiving and fixing them i will test the spray if it works.
Aug 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Brush roller not working on Bissell proheat 7920
my brother changed the roller belt, but now the rollers won't stay up so I can move the cleaner and the water isn't getting sucked up.
Apr 17, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Change the belt on the brush
Dear Norrfam87,here is a website with the manual for your Bissell 7920.
http://www.bissell.com/images/UserGuides/7920.pdf
On page 18 and 19,they tell how to replace the belt !
I hope this helps,EarlsOK
Dec 08, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
