Question about Biostar M6VLQ Motherboard
I can`t get in to set up menu
I don`t know how
  • calskeys Aug 21, 2008
    System works 'fine' except I can not get it to enter setup for BIOS. I have tried DEL (which worked in the past albeit NEVER onthe first try) also tried F2 and then all other key combinations I could think of - all for naught. Any ideas or programs that might accomplish my goal of getting to setup would be appreciated. Have also tried turning off any possible program obstacles - Norton Antivirus, firewall etc.
  • 10 Answers
Press Delete button or F2 button while you restart your system.
Posted on Jun 09, 2008
I don't know how to set the alarms.
If you plan on using the iPod alarm feature on a regular basis, it is possible to place the "Alarms" menu option on the main menu. Go to the "Settings" option and select "Main Menu." Scroll and highlight the "Alarms" link and click on it to place a check next to this option. It will appear on the main menu.
Dock Station
Jun 18, 2012 | Audio Players & Recorders
Don't know how to use
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Language.
4. Select a desired language.
Jan 27, 2012 | SanDisk Sansa Clip MP3 Player
How do i get reception with only a cable connection...no box. i don't know what settings to have the tv on.
In the main menu select "CABLE" AND NOT AIR.
With the cable connected to the coax fitting then turn set on and look for AUTO PROGRAM------engage that and the set will scan thru all the available channels.
If it misses any you can with the remote direct enter a channel and in the main menu "add" it to the up down memory.
It is also helpful to "skip" out channels you do not want in the up/down memory-----this is in main menu also.
I usually skip out the Golf channel and others I never watch.
Let me know if you have questions.
Dec 07, 2011 | Toshiba 51H84 51" Rear Projection...
I don't know how to change the time and date
  1. Press the CONFIG button.
  2. Select Time and Date Settings.
  3. Select Set Time or Set Date.
  4. Turn the MENU/SELECT knob to adjust the highlighted value.
  5. Press the MENU/SELECT button to select the next value.
  6. To save the time or date and return to the Time and Date Settings menu, press the BACK button at any time or press the MENU/SELECT button after adjusting the minutes or year.
Jul 01, 2011 | 2010 Chevrolet Camaro
Hi i need to set gprs setting manually on my mileston xt720 i check the phone but don't know how to change it .please help
Firstly, bear in mind your carrier's APN settings. Contact they, in case you don't know such data for sure.
Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in a 'Name' for it, and, at least, your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, prior you've started making these changes.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards,
Carlos
May 07, 2011 | Motorola Mobility MILESTONE XT720 Cell...
I have 3 out of 4 Asus VK222H LCD Monitor Menu/Brightness Appearing w/o Button Press, stays onscreens for varying amount of time, then dissapears for a while to return again. Monitors bought August 2008....
Mine did the same. I don't know what caused it, but removing the menu button solved it. Crude but effective.
I took a knife, pried out the Menu button, then took a pliers and removed the little black plastic button and problem solved.
Now I can't change the settings, but switching between VGA, HDMI, and DVI works just fine. No more annoying brightness pop-ups that don't go away!!!
Apr 05, 2011 | ASUS MW221U LCD Monitor
I don' t know de printer' s ip address. how I can learn it? the printer is tallygenicom 8008
You can print a configuration page this will show you the current IP Address set in the printer, this Can be printed in the follwoign way;
  • Place printer OFFLINE
  • Press MENU / ENTER button
  • The display should read TEST MENU (if it does not press > repeatedly until it does)
  • Press > until CONFIG PAGE is seen.
The printer will print out a configuration page this will show the network settings
Dec 01, 2010 | TallyGenicom 8008 Laser Printer
Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
Jan 18, 2009 | Apple iPod nano
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Biostar M6VLQ Motherboard Logo
37 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
