Question about Danby DKC645BLS Compact Beverage Cooler
Led readout led read out is stuck on LE wont let me do anything tried unplugging and plugging back in!
  • 254 Answers
Your pobably have a bad touchpad moisture gets into it and it stops responding...you may also not be able to adjust the temp. I can ship you a new touch pad runs $22.75 w/ shipping and handling - Erin 509-928-7176
Posted on Jun 12, 2008
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
My kitchen aid oven stopped working. The stovetop and LED readout Control Panel works fine. The convection oven and broiler do not work. Any suggestions?
Have you tried the "hard reboot" (e.g. unplug for several minutes then plug it back in)? I have a GE Profile oven that I need to do that with periodically otherwise it keeps the oven door locked!
Dec 25, 2014 | Kitchen Ranges
Start/stop lights are flashing with "50" minutes readout. should be OFF. how do I clear it for good?
these dryers have alot of board problems i've seen them beep and then start up by themselves gotta love frigidaire,the computer board took the place of the timer so if the dryer didn't advance to off and got stuck in the same spot you knew it was the timer,so if it doesn't count down and beeps it sounds like a board issue and sometimes the board can't read itself out and you won't get a code.try unplugging it for like 5 to 10 minutes and then plug it back in to see if it resets the board but it probably will go back to doing the same thing
Jan 11, 2018 | Frigidaire AEQ6700FE Affinity Electric...
Computer read out stuck on full
Assuming this is the readout on the server and not the LCD of teh brewer.
Clean out the servers with detan tablets following manufacturers instructions. Rinse and dry. If display remains unaffected and reads full then the sensor is likely faulty and this means a replacement section.
Jun 04, 2013 | Fetco International LUXUS® 5000 CBS-52H-15...
Got "LE" mark on LED
Hi
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | Washing Machines
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
2006 harley ultra classic CD was stuck which le...
06 with original 6.8 version software locks up when attempting to read a CD and experiencing an error. If you opened it and removed the disc, the radio is done. Cannot be reprogrammed out of that mode. Try the Harley exchange program from your dealer.
May 20, 2010 | Harley Davidson 426290 AM/FM Radio
What does it mean when the washer LED reads LE? It is not working and LE is all that shows up.
Le is potential motor problem.I would reset the machine by unplugging for a couple of hours
Nov 10, 2009 | LG WM2688HWM TROMM SteamWasher
E68 readout on the panel
frigidaire dryers have problems with the computer boards,i've seen the affinity dryer start by itself,it will start to beep and then i can start up,but that error is telling you one of the buttons are stuck,if all the buttons check good you have a bad computer board.hope this helps you out.
Feb 13, 2018 | Frigidaire GLGQ2152ES Gas Dryer
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC645BLS Compact Beverage Cooler Logo
310 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
