Question about Olympus Stylus 790SW Digital Camera
Not working. i hav had this camera for over 6 months. however today was the 1st time i went into the pool water with it. i used it for about 10 mins. and it starts flashing pink. then i let it sit out... and a few hours later i go to turn it on and the lens opens but the screen stays black.. no the camera wont even close the lens.
  • amanlikechri Aug 10, 2008
    I've also had that problem, had it for around 4 months now.Took it to the beach and when i got home it wouldnt come on in camera mode, the playback was fine but it wouldnt show anything in photo mode, left it for a few hours and then when i tried to turn it back on the screen was pink with alot of scratchy lines when i tried to take a photo.. I'm annoyed after spending so much money for a camera!!
Seems like olympus got us in!. I have the same problem. I called Service & Guarantee center in Mexico. They told me to send it to them: They will evaluate if the guarantee covers the damage. They also said the procedure about waterproof checking. If there is a sand grain or a hair in the rubber-type seals, and it licked thru those, the guarantee is voided and i have to pay for repair. Good God, the camera is water proof, shock proof but hair and sand proof! hope to find an answear soon. I am about to throw it into the basket if the brand will come with an excuse like that.
Posted on Jul 24, 2008
I have a 6 person hot tub just got last month and we've been having issues first it was really foamy then got extremely smelly scummy and stinky drained it today and it's still so scummy
excessive foam and stink are most times an indicator of wrong water chemistry , purchase a std water chemistry kit from your pool supply center or take a water sample to your local pool supply center and have them test it for water quality , they also should be able to suggest what the proper method of fixing it is
Jun 07, 2015 | Pool & Spa
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
Our pool is cloudy, we got rid of the alge but cannot clear the pool. Have had this system over a month and still not clear . Followed install directions but no luck
This is a sign of not running the system long enough... 1st, make sure you have the correct amount of salt... The manual is very conservative... I have a 18 X 33 oval pool and I run my pump in the summer at 10 to 12 hrs with the chlorinator at 8 to 10 of those hrs and have very clear water.. If I drop from those hrs, my water starts getting cloudy and the sides of the pool get green...
Hope this helps and if it does, please rate!!!
Jul 25, 2011 | Intex Automatic Salt Water System for ...
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
How i can loose tummy
Hello Dear
If you really want to loose your tummy, do the following easy exersise (if You are not asthamic) any one
1. Climb Stairs 10 to 15 times a day. Start with 5 times then increase it by 2 times daily that is
1st Day= 5 times
2nd day= 7 times
3rd Day= 9 times ..... and so on. till day 10. Increase it to 20 times a day and then stop increasing vut continueing your exercise. In 35 days You will feel the difference in your tummy.
2. Cycling: Lay down straight on your back with your hands under your head. And in air use your legs like you are cycling in air... Start this with 5 mins daily and proceed it to 20 mins daily.
It will take you a month and you will feel your tummy loose as faster as any other procedure or machine using exercise.
Note: Exercise 2 is proved by 10 other peoples. It is Granteed.
If you like my Solution please rate it.
best wishes
Mar 03, 2011 | Healthometer Health o meter Body Fat...
Digital sport head camera e-at18g
I've the same cam, without any problems... Clean the battery contacts in the batterycap and down in the batterycase... Should help!
Jun 14, 2009 | Oregon Scientific AT18 Digital Camera
Camera stopped working
There is an warranty for two years for this camera.
Ask your Panasonic repair center and claimed your warranty
Rob Rotronica
Apr 03, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
X-10 used for pool components
it could be that the remote get wet (water contact) did you try to use it agian ?
May 24, 2007 | X-10 HR12A Remote Control
Olympus Stylus 790SW Digital Camera Logo
130 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
