Question about Singer 5050 Mechanical Sewing Machine
Singer 5817c I have atiming issue on my machine where the needle comes down and hits the metal underneath the bobbin and breaks or bend the needle. Any suggestions?
  • 3 more comments
  • Barbara Grant Jun 15, 2008
    What a great relief - I am up and running once again and it was so easy! Thank you sooooooo much!!
  • nzkiwisam Aug 09, 2008
    Singer Model 5050. Needles have been bending like they're hitting the metal in the bobbin section & now the bobbin thread won't even catch. I'm guessing this is a timing issue but I'm not sure how to resove it or even adjust the needle height on this model.
  • monicag Oct 07, 2008
    suggestions?
    I opened up the machine (and gave it a good cleaning) but now the bobbin thread is not catching and the nothing is moving (in the bobbin rotater thinger) Thanks! almost done with a project and of course it has to break NOW~! Please help.
  • Lura Jones
    Lura Jones Jan 15, 2009
    I have a singer 5817c with the same problem. Can I adjust it so the needle quits hitting the metal thing under the bobbin?
  • Anonymous Mar 28, 2014
    Needle fools bobbin
    holder and breaks needle
Hi, actually I can help with your problem but maybe you can help me with mine. A friend gave me the same model...without the instructions. Would you be willing to give me a pdf scan or photocopy of the manual, please? Let me know at arielle.bkshlf@gmail.com. Thanks!
Posted on Jul 19, 2008
Singer model 640 needle hits metal in bobbin area on downstroke
Yep, it's out of time. Take it in for service. Ask for cleaning, lubing and re-timing. Otherwise they will just time it and if it is dirty and dry... it may just fall out of time again.
Also remember you can never turn the hand wheel backwards to the way it is intended to go... that causes this issue in some machines.
Aug 25, 2012 | Singer Sewing Machines
WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD - HAVE NOW BROKEN TWO NEEDLES. THEY BEND AND SNAP AS IF THE MACHINE IS OUT OF SINK WITH ITSELF.MY MACHINE IS A SINGER INSPIRATION 4220 . (I DONT REALLY KNOW...
Make sure the needles are installed with the flat side facing the back of the machine.
Open the bobbin area and hand walk the needle down to see what it is hitting.
Check the bobbin case and shuttle to be sure they are in place.
Needles can also bend and break if they are too small for the thickness of the fabric.
Feb 28, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin holder turns so the needle hits the holder and breaks.
Out of alignment means the timing is off...take it to a pro to have it cleaned and re-timed...if that's the real problem.
However, it seems that you think the issue is may be a bobbin holder that wasn't installed properly??
Do you have a top, side, or front loading bobbin?
Sorry...I don't understand: "If I manually turn the bobbin and holder clockwise just as the needle comes down, it goes all the way down without breaking or bending."
Do you mean that you're turning the hand wheel towards yourself...and that works properly? If so, it's probably not a timing issue.
If you have a metal bobbin case that you insert a wound bobbin into and then place that bobbin holder w/bobbin into your machine...perhaps the bobbin case just needs a slight turn in order to snap into place.
If that's not it, check your machine's manual to see what part might be missing...then, to find that small, shiny metal part, try shining a flashlight across the area where it was lost.
Apr 06, 2017 | Brother XL-2230 Mechanical Sewing Machine
Singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Apr 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
A bent needle will hit the metal. If it continues you will need to adjust the needle carrier. hopefully that isn't bent, but if so I don't believe that the replacement of it will be too costly.
Jan 22, 2009 | Sewing Machines
1.Remove the machine needle plate.
2. Remove the bobbin case.
3.Insert a new needle.
4.Turn the handwheel towards you by hand, and watch the
needle going down.It should go down all the way, and start coming Up again, WITHOUT TOUCHING ANYTHING.
Check, and let me Know.
Jun 09, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
505 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
