Question about Mitsubishi MS15TN Air Conditioner
NOT TURNING ON.
CAN NOT TURN ON POWER. REMOTE CONTROL BATTERY IS NEW.
Pls Check the internal wiring from out door to indoor.
or check the supply power.
Posted on Apr 16, 2009
Tv not turning on
reset the r.control, take out the battery and put again the code and try it.
if the problem persist, clean the contacts battery, and replace by new ones.
clean the keypads. test the remote control with digital cameras or webcan cell see the picture, the LED from r. control must be ON, when you touch any KEY, othewise proceed as indicated above.
Jul 04, 2013 | Televison & Video
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
My battery in my remote were taken out and when this was done I was unable to use the remote to control the cable/T.V. when the batteries were replaced. I set up my remote to turn the T.V. on and off, but...
If the remote control is not broken, the batteries are almost out of power supply. Especially with remote controls that perform multifunction capabilities like with universal controllers. Replace the remote control with new powered batteries. Important notes include being weary of the capacity battery power supply because some brands are incabable of providing supply to remote controllers. For example, unless the remote control requests specific brand battery power supplies, energiser or duracell bateries would power up any device.
Jan 08, 2011 | Televison & Video
I have a hampton bay ceiling fan/light and the remote came with it. The remote model is: UC7083T. The battery died and when I installed a new battery, the remote willnot connect with the fan/light. Any...
try turning off the switch/circuit breaker at the main lighting panel. Then just turn it back on. Worked for me.
I'm guessing a capacitor in the remote is holding a charge and causing the problem. You'll probably need a new remote soon thiough.
Nov 27, 2010 | Universal Remote Control Hampton Bay...
FRONT POWER LIGHT AND DVD SIDE LIGHT ARE BOTH ON BUT I CANNOT TURN ON THE TV NOR OPERATE THE DVD. I HAVE PLUGGED OUT THE TV FOR THE DAY AND THERE HAS BEEN NO CHANGE.
I'm not sure if you've already tried replacing the battery of the remote control which is usually the common issue. But if you have, and it's still not turning on, try manually turning on the power directly from the TV by clicking on the up/down Channel. Because it is highly unusual if you cannot turn on both the TV and the DVD. So it is mostly likely a remote control issue. You can also try using another remote control of the same brand to see if it would work. Hope this helps.
Oct 22, 2010 | Televison & Video
I can not turn on the receiver with the remote control, turning it off works. What can I do? Please Thank you in advance,
Must have a bad remote control then . Did something spill onto the remote near the power on button? Short of getting a new remote you could try poping thr remote control apart and cleaning it out with a mild detergent. Larry's Electronics
Apr 28, 2010 | Sony STR-DE325 Receiver
Dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Jan 09, 2009 | Dometic Rooftop RV Air Conditioner
Tv turning back on when turned off.
Thanks for helping me understand this problem. I've placed new batteries in the RC but, that don't help. It's the RC that came with the TV when I purchased it new.
bessylou4@yahoo.com
Aug 12, 2008 | Televison & Video
Fan and remote not working
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Mitsubishi MS15TN Air Conditioner Logo
155 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
