Question about Singer 5050 Mechanical Sewing Machine
I have a singer 5817c
I believe the timing is off - when the needle comes down it hits a part beneath the bobbin and breaks. I took it in for repair and it came back doing the same thing. They said it is a "timing issue". There are no singer repair centers in Colorado and the place I was using was forced to close with 2 days notice by the bank!
    Problem Solver:
  • 26 Answers
1.Remove the machine needle plate.
2. Remove the bobbin case.
3.Insert a new needle.
4.Turn the handwheel towards you by hand, and watch the
needle going down.It should go down all the way, and start coming Up again, WITHOUT TOUCHING ANYTHING.
Check, and let me Know.
Posted on Jun 09, 2008
I have a Singer 95-1 and the needle is hitting the bobbin, what can I do to fix this without the needle breaking?
your machine needs timed. Unfortunately, the only thing I found for you was a parts list. I did not find any service manuals for you.
http://www.parts.singerco.com/IPpartCharts/95-1_2.pdf
Your best option is to find a sewing machine repair person. Good luck
Dec 20, 2012 | Singer Sewing Machines
My needles are breaking when i thread in my 5817c seems to be hitting
Unfortunatlly it sounds as though its out of time. Look on my profile I wrote a tip on timing.
Sep 25, 2010 | Singer 5050 Mechanical Sewing Machine
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
Singer 5817C bobbin pulls out of casing
This will happen if the bobbin is put in the wrong way around - I believe the thread should be going in a clockwise direction as you face it. (If this is the way you have it, try the other way!)
Mar 13, 2009 | Sewing Machines
Breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Feb 14, 2009 | Singer 8280 Mechanical Sewing Machine
A bent needle will hit the metal. If it continues you will need to adjust the needle carrier. hopefully that isn't bent, but if so I don't believe that the replacement of it will be too costly.
Jan 22, 2009 | Sewing Machines
Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Jan 19, 2009 | Singer 3116 Simple
The needle goes down into the bobbin casing and breaks off.
I don't know if this will work, but sometimes the thread in my machine gets too tight because I hold it in place with a water bottle cap, but then my needle gets pulled too far away from where it is supposed to go, and it bends and hits the bobbin plate, and then it just breaks.
Dec 11, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 5817c
Hi, actually I can help with your problem but maybe you can help me with mine. A friend gave me the same model...without the instructions. Would you be willing to give me a pdf scan or photocopy of the manual, please? Let me know at arielle.bkshlf@gmail.com. Thanks!
Jun 09, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
207 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
