Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera wont turn on
The little green light comes on but the zoom doesnt extend and the screen doent light up. How do i fix this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jan 21, 2013
3 Suggested Answers
  • 374 Answers
SOURCE: Casio EXILIM ZOOM EX-Z850 Zoom button doesnt work
You have to send it in to repairs. You're lucky that the lens even still comes out.
Posted on Jul 08, 2007
  • 374 Answers
SOURCE: Zoom extended but no power
You are going to have to send that in to be fixed. Even if you call tech support they would tell you that.
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
How you can eliminate the sign on E:61:00 the camera sony DSC T-5 series Cybershot
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks and Keep using Fixya
Mar 11, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
E:61:00 on sony cybershot camera
To solve this
Mar 02, 2011 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony Cyber-shot Error Code E:61:00
you may have these symptoms,
Symptoms :
  1. After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  2. Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  3. Zoom in and zoom out would not work.
  4. Playback mode and the Setup mode was not affected.
To fix this problem,
Do these...
A) Put the camera about a half inch from a hard surface.
B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
A) Turn it on and let the lense go out fully
B) See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed!
If not, try these steps a few more times. If still nothing, then I suggest you to call Sony, but this DID work for 90%, so hopefully it''ll work for you :)
Thanx for using fixya,
Cheers.
Sep 27, 2008 | Pentax Optio S50 Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
