My NEC Versa E6000 monitor is so dim it is impossible to see. I have had to use an external monitor. The brightness control (Fn-F9)does not appear to work - is there anything use I might try?
    Problem Solver:
  • 7 Answers
It is likely your monitor's backlight has gone out. On LCD monitors like the one in your laptop, the Liquid Crystals can only be seen clearly when excited by light. This is not a user-servicable part and typically requires replacing the entire LCD monitor. I would recommend a new PC because of the high cost of replacing this part. Or, continue using an external monitor.
Posted on Jun 09, 2008
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
Gateway p-6831fx not connect to external monitor
Have you connected it before, or is this your first time trying? I know that some laptops have different function keys you must press for the screen to appear. Try fn f8, fn f7, fn f9. It depends on the computer. Hope I helped.
Oct 25, 2012 | Gateway P-6831FX Notebook
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
Monitor to bright
Decreasing Screen Brightness (FN+F9)
Press and hold the FN key, then hit the F9 key to decrease screen brightness.
Increasing Screen Brightness (FN+F10)
Press and hold the FN key, then hit the F10 key to increase screen brightness.
Mar 21, 2012 | HP Compaq nc6230 Notebook
Deem light in display
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1.Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2.Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3.Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4.Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful.
Aug 26, 2011 | IBM ThinkPad R52 Notebook
Dark picture on monitor
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
I got a ADVENT Modena M201 Laptop and I know how to turn the webcam on but there's no programme on the 'all programs' tab for it. When my friends are round I would like to take pictures with them but its...
Below please find key - function overview.
Fn + F7 will turn on/off the webcam
It might help you.
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Feb 27, 2011 | Computers & Internet
I have a advent m201 laptop . how do i turn the built in webcam on please
Try this
Fn+F8 - Mute Sound
Thanks
Dec 30, 2010 | HP Pavilion dv6000z Notebook
What are the functions of the keys on the dell 1745. F1, F2, keys with the symbols above them?
Fn + F1 Change Display Device. Fn + F2 Wireless Control Fn + F3 Battery information Fn + F4 Decreases brightness on the integrated display only (not on an external monitor). Fn + F5 Increases brightness on the integrated display only (not on an external monitor). Fn + F6 Keyboard backlit(available only if a backlit keyboard is installed) Fn + F7 Mute Fn + F8 Decrease audio Volume. Fn + F9 Increase audio Volume. Fn + F10 CD Previous - Play previous media file. Fn + F11 CD Play/Pause - If there is Audio CD in system, Media player will play music. Fn + F12 CD Next - Play next media file.
Jan 08, 2010 | Dell Studio 17 Notebook
Unable to use external monitor, comes up black even though its working
I believe NEC has Fn key combinations that not only toggle the video output selections, but there is another that will turn the display on and off. I know on HP, the video toggle combination is Fn + F4.
Oct 20, 2009 | NEC Versa VX Notebook
Computers & Internet Logo
David Payne
David Payne
