Question about JVC RX-6020V Receiver
No voice sound from receiver
I have a JVC RX-6020V. When i put in a DVD, i get all the backround noise, but not voices. I looked at all the connections, and they look good to go. Not sure what to do.
You might also check the audio stream that you player is using and make sure that you are playing the voices. i had this problem once when i started using VLC media player on my PC (i run my PC threw this amp)
Posted on Apr 08, 2009
    President:
  • 624 Answers
Sounds to me like you have not got the cener speaker working properly. Try another surround mode, then check the speaker by switching it with another known good one just to make sure i the problem is the speaker or the receiver. You can also do the speaker test and make sure the center speaker is set to be turned on in the menu settings.
Here is a link to the owners/operation manual and you can find any information you need to check your receiver out. If you never are able to get it working, you need to take it to a service center to be checked out.
Get your manual free here:
http://books.jvcservice.com/booklist.asp?Model=RX-6020V
A "FixYa!" rating would be appreciated, and let me know if you need any more help,
Dave
Posted on Aug 07, 2008
Background sounds louder than voices
get the graphical user interface up on the TV,and adjust your sound levels.some amps also have supplied microphones for setting up their sound levels.you want about +8 DB on centre channel
Jul 05, 2010 | Yamaha RX-V663 Receiver
Digital input has no sound even though all settings have been set correctly
New install or new problem on old equipment?
ALL digital inputs or just one?
If just one, look to the source or its cable.
If everything is done correctly it should work.
Jun 07, 2010 | JVC RX-6020V Receiver
My problem is different. If I unplug it my receiver takes two to three weeks before it comes back on. It's always taken a few hours in the past and even referenced it in the manual but this is ridiculous
the temperature inside of your receiver unplugd is to cold to start the powersupply or other electronics
replace the capacitors of the supply and this problem will be fixed.
the value is bethween 470/uF25V and 2200uF/40V
they are located near the transformator
Feb 15, 2010 | JVC RX-6020V Receiver
Backround sound is fine but voices speaking are muted
I'm not sure of this system but if this was mine I would say it sounds like your playing this in a 2-Channel mode which eliminate the center channel.
you music may be set up fine, but the mode you play a dvd in may be set up for 2-channel mode. try a dolby prologic 5-channel or some other mode if you have one.
Mike
Oct 18, 2009 | Audio Players & Recorders
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I Need help
Here is a link to get your owners/operation manual for the model you indicated. It has two listed, the bottom one is most likely yours.
You will get all the instructions you need to connect your unit properly.
A "FixYa!" rating would be apprecieated, since this all the information you really need.
Let me know if you need more help,
Dave
Aug 07, 2008 | JVC RX-6020V Receiver
It says overload
All the speakers connected right?
ANy speaker fuses not accounted for?
If you moved , someone may have dropped it or bonked it enough to crack a printed circuit board. That would make things unpleasant.
It's fairly easy to fix a cracked PCB if you know what to look for.
Feb 20, 2008 | JVC RX-6020V Receiver
Actors voices
Hi....
If your system is set up for surround and you dont have a center speaker that will happen.
Check the manual for best setup
Jan 05, 2008 | Pioneer VSX-D711 Receiver
JVC RX-6020V Receiver Logo
195 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
