Question about SanDisk Sansa m250 MP3 Player
Cant find driver online for sansa m250 id like to put music on it, i have win xp....
  • 5 more comments
  • lemonseed Jun 12, 2008
    I know the Sansa doesnt need an additional driver, but it does not plug and play here but the link given does not work either....
  • Anonymous Aug 27, 2008
    the Computer doesnt recognize sansa m250 when pluged on it
  • Anonymous Aug 28, 2008
    dont work on my pc i have win xp sp2
  • armydogs Sep 01, 2008
    When I plug in my sansa, nothing happens except my pc recognizes new hardware. I go to windows media player where my music is but it will only let me burn to a cd. When I clikc burn to a device, it says it is not able to. What am I doing wrong? How can I copy my files from my windows media player to my sansa mp3 player with windows xp?
  • Anonymous Sep 07, 2008
    cant find driver
  • agravimacs Feb 15, 2009
    cant find driver online for Sansa m250 MP3 Player
  • Anonymous Apr 11, 2009
    I've reinstalled factory settings and to load Windows Media Player 11 I have to install over 500meg of updates from windows updater which takes a lifetime on a dialup connection. I'm beginning to dislike the hoop jumping Microsoft inflicts on simple problems. I'll try solution 3 below but I Feel all your pain out there.
  • 8,596 Answers
Win XP does not need an addl driver - it should just plug and play; check Sansa's driver page as a precaution:
http://www.sandisk.com/DriverDownload/driverList.asp
Posted on Jun 09, 2008
  • Corey Knoettgen
    Corey Knoettgen Jun 12, 2008
    Sorry - they are always changing that link - this is the 3rd time I've had to change it. Here is some good preliminary info:
    The most common reason for this problem is not
    having the latest Windows Media Player installed, or having a Windows
    OS version that is not supported by the Sansa player.
    The Sansa
    players support Windows XP SP2 and Windows Vista and above. If your
    operating system version is supported by the Sansa player, there are 4
    solutions you can try:
    SOLUTION 1 – Download and install the latest Windows Media Player
    SOLUTION 2 – If you're running Windows Vista, apply the following hotfix - KB940199
    SOLUTION 3 – Download and Install the MTP Porting Kit
    SOLUTION 4 – Try connecting the device to the PC using MSC mode
    View/c200: Turn on & press and hold the rewind button while connecting to the PC
    Fuze/e200: Go to Settings > System Settings > USB Mode & select MSC
    Clip: Go to Settings > USB mode & select MSC
    -Tha Mp3 Doctor
Sol 4 worked for me too
Posted on Dec 13, 2009
Hey thanks that was great!
salution 4 worked for me.. some how the MSC was changed..
Posted on Sep 09, 2008
How to remove music from sansa m250 that is no longer on computer
ok, plug the mp3 into your computer, click on my computer, then where it says removable devices you should see your mp3 listed, double click it. browse the folders listed until you find the songs that you want to delete , when you find one you want gone RIGHT click it then click delete/ It should then remove the song from your mp3 and put it into your recycling bin.
Jun 23, 2009 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Delete music
when you plug it to usb cord and the computer then you can "reformat" that is the only way to remove music...you need a computer, don't use Vista it is not compatible with anything yet...
use windows xp and when you plug in your mp3 player m250 it will ask you which program to choose from to open your files on the mp3 disk...its easy...
Jun 23, 2008 | SanDisk Sansa m250 MP3 Player
Cant hear music
Make sure the songs are in the right format. Also, the SYS folder was the wrong folder to put the songs in. Just use Windows Media Player like the manual suggests - it will make life easier.
Jun 15, 2008 | SanDisk Sansa m250 MP3 Player
The pc doesn't recognize the m250
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
download the sansa connect recovery tool
download the manual and it will tell you how to reset your mp3
Feb 26, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 2GB
Try going to menu, then settings, then USB and then select MSC instead of the auto select. Hope this helps.
Jan 03, 2008 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP#
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstalling the battery without pushing any further buttons.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 30, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
M250 sandisk
Dec 13, 2007 | SanDisk Sansa m250 MP3 Player
I dont know what the problem is
Hi I am not an expert by any means, but when I had issues with my M250, I went to the Sansa site and downloaded the latest firmware onto the M250 and my problems disappeared. Good luck
Feb 11, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
4,543 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
