Question about Keurig Special Edition B60 Coffee Maker
No ready que
The power is on, but it never flashes ready to brew.
  • Anonymous Dec 03, 2008
    not ready light continues to blink...
  • Anonymous Dec 27, 2008
    Brand new out of the box, the Not Ready Light blinks and stays on for the entire time it is plugged in. Has not made one drop of coffee. Well not prime, pump water or do anything but alink Not ready. Can this be reset?
I received my B60 from Ebay and when it came the "not ready" message was blinking. I called the company and honestly told them my problem and also mentioned that it was an Ebay purchase with no warranty. They fixed my problem for free anyway, and were very friendly. I will definitely consider purchasing more from them in the future based on this experience. We reset my machine by doing the following two steps:
1. Press the small and medium cup buttons at the same time then immediately press the menu button three times.
(the number listed there showed how many cups of coffee the machine had made--mine said 0:04 which was four cups)
2. Hold the medium cup button and hit menu button then the small cup button quickly while still holding the medium button then release the small and medium quickly.
Posted on Dec 30, 2008
2 Suggested Answers
SOURCE: The machine says REady To Brew- the lights flash
Mine does this all the time. When it does, I tap the top of the machine and the coffee comes out. I don't know if it will work for you, but it works every time for me. It's like there's a small clog or something.
Posted on Nov 17, 2009
How do I fix a Keurig V1255 with a flashing LCD display?
Keurig Platinum Reset for the Not Ready Light - YouTube
? 1:21
https://www.youtube.com/watch?v=xjWIQpttTc8
Jun 22, 2010 - Uploaded by Lsailor1
This is a reset method for using on the Keurig Platinum B77 coffee ... Show more ... set to brew in morning ...Missing: v1255
Fix Keurig Vue V700 Not Brew
Nov 14, 2015 | Vue V1255 Professional Brewing System...
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Keurig mini keeps asking to add water
Needs cleaning and reset the system with a full flush and Calc.
Feb 04, 2013 | Keurig B31 Mini Plus Brewing System
Directory shows "Ready to Brew". How do I start
Sorry to read about your problem, I hope this helps you out.
Just hit the big button, its flashing have k cup in and handle down
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
i
Dec 21, 2010 | Keurig B60 Coffee Maker
Our keurig just flashes not ready
Try to de-scale the machine. Also, refill reservoir and then try to brew. Sometimes it needs to be re-set before it can start to brew.
Nov 08, 2009 | Keurig B70 Coffee Maker
The machine says REady To Brew- the lights flash and i press the button to brew. It says "brewing" but nothing ever comes out and then it goes back to "Ready to Brew".
Nov 01, 2009 | Keurig Special Edition B60 Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Aug 10, 2009 | Keurig B60 Coffee Maker
Automatic brewing
Here is a link to the manual:
http://useandcares.hamiltonbeach.com/files/840156002.pdf
Hold PROG until clock flashes. Continue holding PROG button;
press H and M until the desired
brewing start time is reached.
Press PROG momentarily to
activate automatic brewing.
Mar 25, 2009 | Hamilton Beach BrewStation 47665
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
Keurig Special Edition B60 Coffee Maker Logo
1,012 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
