Question about VIA P4MA Motherboard
Lost internet connection - after installing graphic card
I have a ECS l4vxa2 ver 1.0 motherboard. I changed my video card to a nvidia 6200 OC (pci) card and lost my internet connection.
I've tried my cable co and router tech support. They say it has something to do with the motherboard or graphic card. Spoke with graphic card tech support they say something about graphic card taking power away from ethernet. I switched back to my old card and still no connection - their tech support says issue with power being taken away by graphic card but would not tell me how to solve the problem - said not their cards fault.
Please help
  • sh23jk Jun 09, 2008
    not a power problem
    it had something to do with available resources or memory....
  • 10 Answers
If this is the power problem then change your SMPS with more Wats power.
Posted on Jun 09, 2008
My graphics card is not being recognized. Im using a ECS 945P-A Ver: 3.0 motherboard which has no on board video output. im using a Zotac Technology GEforce 7300 GT graphics card too. Do I need a powe
I don't believe that graphic cards of that level need PCI-EX power directly from the power supply (using a power supply cable with a PCI-EX connector). This is a good thing, but that's because this is a low-level card--one that likely needs nVidia legacy drivers: It's likely that active driver support has ended. (The same is true for legacy AMD/ATi cards--and other more ancient cards, as well. ((PCI or AGP) Sabre, 3DFX, etc.)
If you're using the VGA port--perhaps the card's DVI port is needed for initial install, instead--or vice-versa. (You'd need an adapter or different cord to run to a VGA monitor or TV's VGA port .)
Rarely, two VGA ports might exist on a card, instead. In any case, the port needed likely isn't the one connected (with a ribbon cable) to the PCB on the video card. (Once you get a workable video card driver installed, then you should be able to use either port.) Try all usable ports before finding another possible solution....
Apr 05, 2014 | ECS 945p-a Intel 945p Socket 775 Atx Mb...
Looking for advice on a video card. Would a radeon hd 5750 run on c51gm motherboard
1) You have a PCI Express x16 expansion slot, for a graphics card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135010
(Orange)
A) 1GigaByte of graphics memory which is GDDR3. (It is GDDR3, not DDR3; trust me)
B) 800MegaHertz Core Clock
C) 1600MHz Memory Clock
D) API's - DirectX 11
Open GL 4.1
Shader Model 5.0
2) The motherboard chipset is an Nvidia GeForce 6100 - Northbridge, and an Nvidia nForce 410 - Southbridge.
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series_chip_specifications
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
Nvidia GeForce 6100/nForce 410, came out 2005.
3) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Northbridge chip of the motherboard chipset, handles the Faster capabilities of a computer.
Processor (CPU), Ram Memory, and HIGH-speed graphics.
AGP technology, and PCI Express technology, ARE HIGH-speed graphics.
Using a PCI slot for a graphics card, or using Integrated Graphics; is NOT high speed graphics.
(As you can see in the Motherboard Diagram, the PCI bus is controlled by the Southbridge chip. The Southbridge chip handles the Slower capabilities of a computer.
Means anything connected to the PCI bus, such as a graphics card in a PCI expansion slot; is handled by the Southbridge chip.
Integrated graphics also )
4) PCI Express came out 2004.
Went from PCI Express 1.0 version to PCI Express 1.1 version.
In 2007 PCI Express went to the 2.0 version. PCI Express 2.0.
Your motherboard, IMHO, uses the PCI Express 1.1 technology.
This is why I recommend a graphics card based on the PCI Express 2.0 technology. (For one)
PCI Express 2.0 is Backward Compatible, with PCI Express 1.1
A little iffy if it's PCI Express 1.0
I have seen a lot of problems crop up with users trying to use a graphics card, based on the PCI Express 2.1 technology; on a motherboard based on the PCI Express 2.1 technology.
That's why I recommended PCI Express 2.0
PCI Express 3.0 is supposed to overcome that, (Use on a mobo with PCI-E 1.1), but I have no real world knowledge, (Hands on), and no input from the 'outside'. (Internet/world)
5) You need at least a 400 Watt power supply. Don't have at least a 400 Watt? Time to move up.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1147669&Sku=U12-41529
Regards,
joecoolvette
Nov 20, 2012 | ECS C51GM-M Motherboard
I lost my cd that came with the graphics card.now what?
Try to download drivers from nvidia website u will definitely get it...
Jun 19, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
I can't install a GeForce 6200 graphics card
Also, if that card has dual outputs, such as 2 DVI connectors, try connecting your monitor to the other one.
Jul 19, 2009 | ASUS GeForce 6200 TC, TD64 Video Card
What video card
i recommend a nvidia 9500gt 1gb vga card. It's phenomenal and purely insane graphics^_^
godlover
Jun 15, 2009 | Dell Dimension 2400 PC Desktop
No video output from Nvidia Geforce 9600GT 512MB
run the onboard if you have one and go into the bios there's normally an option to choose what order to boot graphics devices eg. PCIE>IGP etc hope this helps.
Apr 16, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Graphics card help
> nvidia 9600gt oc graphics card requirements : found at http://www.bfgtech.com/bfgr96512gtoce.aspx
Microsoft Windows Vista -or- Windows XP
> CD or DVD-ROM drive > 100MB of available hard disk drive space for basic driver installation > 425W PCI Express-compliant system power supply with a combined 12V current rating of 28A or more (Minimum system power requirement based on a standard PC configured with an Intel® Core™2 Extreme X6800 processor) > PCI Express-compliant motherboard with one vacant PCI Express x16 slot. > One 6-pin PCI Express supplementary power connector -or- Two 4-pin Molex supplementary power connectors
> 512 MB of system memory
http://www.directron.com/slireadymb.html heres a list of SLI ready motherboards. dont gotta use this site to buy it just giving you and idea of whats out there for you.
Seems from what i gathered that as long as its an SLI ready motherboard with a open 16x PCI-E compliant slot and of course its gotta fit your tower. Find out the form factor of the tower then also make sure that it fits the correct type of ram that you have and prosesser. Then u should be good to go!
May 13, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
VIA P4MA Motherboard Logo
132 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
