Washer spins but not enough to extract water from clothes or tub.
Washing machine performs a limited spin cycle but not enough to extract all the water from the clothes or the tub. Clothes still drip. When you place your hand on the maching during the spin cycle you can feel how weak the spinning is. I have a Maytag Neptune MAH4000AWW machine When it is done washing the clothes are too wet - it appears the water has drained, but the excess water hasn't been spun out of the clothes.
  • 10 more comments
  • stumped4630 Jun 09, 2008
    my washer appears not to be going through a spin cycle leaving the clothes wet after the cycle is finished
  • Anonymous Mar 11, 2014
    i cannot store numbers on my DSE f4504
    How to troubleshoot Horn on 2009 VW CC stopped working
    I have a Radio Shack Universal Remote and Hitachi
    SPEEDOMETER WORKS FINE, ODO/TRIP DO NOT MOVE AT ALL. STUCK ON 144K MILES
    ps3 sticker scratched off
    DRIVERS DE SONY VAIO PCG-7173L
    last time used, maps showed on screen. today, verbal commands were there but no map/streets show
    how do i set the time
    battery good kill switch is in on postion
  • Anonymous Mar 12, 2014
    I lost the manual for the clock radio. I need to find out how to
    set the radio alarm
  • Anonymous Mar 19, 2014
    If some of the wet clothing is removed and then spun, water will be removed from remaining clothing.
    Master:
  • 788 Answers
I'm thinking it could be your timer. Part #9 here: http://www.partselect.com/ModelFrames.aspx?ModelID=263255&ModelNum=MAH4000AWW&mfgModelNum=&ManufactureID=1&Selected=52497&Position=3&mfg=Maytag&Type=&Mark=3 You will need to know if you have a series 10 or 11 machine. The series is the Rev. # next to the model # on the serial number tag. But first of all I want to ask if it does this for every fabric type setting and temperature setting? Are your loads pretty heavy or does it do the same thing for an empty machine?
If all other parts of your cycles are working fine then I would assume your motor and motor control board are OK. Also it would seem as your main control board is working fine. So that leaves the timer, if the cursor stops touching the contact for the spin cycle the cycle will stop. You would have to replace the timer in that case as it cannot be opened and repaired.
If it's not the timer it could be the wax motor but usually there is no spin at all if it's the wax motor.
Posted on Jun 09, 2008
    Genius:
  • 3,422 Answers
he clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Goodluck,
Please don't forget to rate or accept the solution
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
Check for any loosen belt on the spin guide, this may effect the normal spin especially if the tub was loaded wit heavy clothes...
let me know again here..
    Genius:
  • 1,447 Answers
You can dismantle the washer if you have the technical guide for it so that you can check for dirt that might clogged the drain.
    Master:
    Sergeant:
  • 460 Answers
You will have to replace the belt in the washing machine... is it automatic or mannual washing machine...?
    Guru:
  • 1,894 Answers
Then its stuck drain sir
After final rinse and spin cycle clothes are still wet
I can't solve this but am having a similar problem. There is no water in the tub but the spin cycle does not get enough water out of the clothes and they're very wet. This causes the towels especially... to smell really bad. The tub is very loose. How can this be fixed.
Jul 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin Cycle Fails to Extract Sufficient Water
GO TO www.repairclinic.com enter your model number and look for parts 3365 and 2595. If either is worn or doesn't look as good as the pics you may want to change them. And you also may want to tighten the belt more.
Apr 11, 2009 | Washing Machines
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Spin cycle not working properly, clothes still wet!!!!
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Oct 29, 2008 | Kenmore 24032\24036 Top Load Washer
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
May 22, 2008 | Washing Machines
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
it sound to me to be the water pump, with all the water in the tub, the machine dont spin ok, and the water is extracted by centifugal force, not by pumping as it should be, call a tech, this is a hard job for regular people..good luck
Aug 09, 2006 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
460 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
