Question about Compaq Computers & Internet
I put my computer into hibernate, left for about 3 hrs and the battery died. when i got home i turned my laptop on, and the nvidia didnt look right. my desktop screen looks chunky and wide now, what do i do?
  • 49 Answers
Hi Enjoisays,
The issue here seems to be most likely a VGA cards issue. Since you had mentioned Laptop, and nivida, i presume it must be one of those notebooks from either toshiba, dell or acer (to my knowledge at least). If that is the case, it is also most liekly that the graphic cards is built into the motherboard and you must send it back for servicing.
The fact that your batt dies after 3 hours in hibernation also suggest that your priduct may be over a year old and that your batt lifespan is getting shorter. Some good practices when using a notebook is to use thr battery ONLY when on the road. If you're at home, try to use direct power via the charger provided. This will save the batt life for longer usage.
Oh yeah, and also, please note that chunky blots on screen with images not turning out right is def most of the time VGA issues. Hope this helped.
- Technomancer
Posted on Jun 09, 2008
When i put my computer in hibernate mode, it hibernates for about 30 seconds then it turns back on?
When you put your computer into hibernate you arent hitting any buttons? hitting the button will cause it to wake up. Also if that isnt the issue then you should right click the battery in the bottom right hand corner and then click on power management and then manage one of the power options for your computer.
Oct 19, 2012 | Dell Inspiron Computers & Internet
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
My laptop went into hibernation on its own and now the laptop will not power up. I thought it was a battery problem so I got a new one. The laptop worked for about an hour and then went into hibernation...
running the DEAD OS called XP are you? the virus magnet?
why not turn hibernation off first.
here are the firsts list ,
1: new RTC coin cell installed in laptop (tiny battery is first)
NO cell last 15 year old, why run this battery?????????????
very very unwise
2: park the huge new battery on the shelf till PC runs right again.
3: now run on AC power, this must work or the pack is bad (99%?)
4: ok it runs now, go to control panel and turn off hibernate.
CP + power, turn it all off.
now the dead thing,
do the HP long reset posted at HP 1,000,000 times.
  1. big battery out
  2. ac pack unplugged. from PC
  3. push power button for 10 second
  4. release.
this resets hibernate , and other oddities.
Feb 02, 2018 | Compaq Presario R3000Z Notebook
System shuts down automatically
Remove the battery and adapter. Press power button for 30 sec. Then connect the adapter. Press power button. When pc started, go to
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Apr 12, 2010 | Lenovo 3000 Y410 Laptop
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Computer went into hibernation
Hi there.
Try turning on the laptop using AC power only and then please post back.(remove the battery altogether)
Jun 08, 2009 | HP Compaq nx7300 Notebook
When ever i turn my laptop boots properly..then ill be typing and it will shut off..or go on standby not sure then i will push the power button...but it doesnt rootboot ...and starts back up where i...
Try this.
Right click on desktop.
Mouse down to properties, & left click.
Left click on screen saver.
Mouse down to Power In monitor power, & left click.
Check your power settings & hibernation settings.
Also some computers are setup to hibernate if mouse is placed in certain parts of the screen (top right or left, Bottom left or right.
Hope it helps.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
21 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
