SOURCE: AOC color monitor model 9g1rs, dead, ** volt, fuse good
Hi
You need to replace HOT(Horizontal Output Transistor) see number carefully before you replace it.
Thanks
SOURCE: AOC LM729 17" LCD Monitor
Well I just resoldered both coils, and it Worked!!! I was about to throw away the monitor, but luckily found this page!
Thank You!
SOURCE: AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
SOURCE: no power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
SOURCE: no display after 3 secs.
The problem is due to short of two transistors on the PS Board near the high voltage transformer (Q209,Q210 or Q211,Q212 - 2sc5706).
