Question about Creative Labs ZEN Vision:M Digital Media Player
Rebuild Screem I dropped my Creative Vision: M a few months ago (i'm not sure if that caused the problem) and i reset it. Now, whenever I turn it on, it automatically goes to the rebuld screen, but never finishes it. The bar gets about half full then it just goes to the normal screen....but i've noticed some of my songs are being deleted evry time. My computer will not reconize it either, even when the player says it's connected? I could use some help...i seriously don't want to buy another one
  • 8,596 Answers
You have more than one problem. You are missing a screen - cannot be fixed, seriously. And you have a corrupt DB. I would DEFINITELY reccomend replacing the player, BUT a firmware upgrade from the manufacturer will usually resolve this DB corruption. If no firm upgrade is available, the reformat your player - read my "Tips and Tricks" on Reofrmatting players to find out how to do this.
Good Luck!
Posted on Jun 09, 2008
Freezes on the 'Rebuilding...' screen.
The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Turns on and then goes to rebuilding screen then says firmware problem but computer doesnt register that its hooked up
check on the zen site and make sure you have the current version for your zen.
download it and do a rebuild with new firmware.
this mp3 has a hard drive, the exact one that the ipod has. They are not immuned from crashing for sure.
But doing a reinstall of the software will probably help alot.
May 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen not recognized by computer
I was having the same issues with my Zen Vision M : 30 G. It was not recogznized on any computer, and when I turned it on after having it off for a large amount of time (24 hours), it would rebuild half way before completely turning on.
I did a TON of research and found nothing but I finally got my Zen to work by trial and error.  This is how I did it:
Download the MP3 Recovery tool on the Creative Support Website. Make sure that the MP3 player is at least half charged.   Turn on the mp3 player, holding the on power switch in the ON position. (Very important to hold the Power switch!) While holding down the Power switch, reset the Zen by inserting a small object into the hole at the bottom (thumbtack, wire, earring).  A menu will appear: Clean Up, Format (All), Reload OS/Firmware, and Reboot. I chose Clean Up first and this did not work for me so then I Format.  It will remove all of your data on your Zen.   After Formatting, Reboot your Zen and plug it up to your computer. Run the MP3 recovery tool again.   The Firmware should recognize your Zen, and once installed, so should your computer.
I hope this helps!
Sep 30, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision W Phone Jack Messed up
thers not really any solution for this, this is a rare problem. i suggest you take charge and push creative to answer ur questions about the phone jack
Jan 10, 2008 | Creative Labs ZEN Vision:M Digital Media...
It's permanently frozen
Sounds like you have a bad hard drive and will need to get it replaced. You should take it to a technician, or if you feel confident enough, buy another hard drive and install it yourself.
Aug 30, 2007 | Creative Labs ZEN Vision:M Digital Media...
Neeon Dead!
Have you tried resetting it? Right beneath the lock swithc is a small hole. Inside it is the reset button. Try using a needle or hair-pin to reset it and see what happens, when mine had a freezing problem a few months ago that fixed it straight away..
Mar 26, 2007 | Creative Labs Zen Neeon MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
141 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
