LG GC990W VCR displays envelope icon on TV screen.
I keep seeing a small white envelope with an A on it on the right hand top corner of my TV screen. I suspect it has something to do with my vcr - I have an LG GC990W VCR. It only shows up on one channel and not on the others. Can anyone help with this? Thanks!
  • ronydoug Apr 13, 2009
    I keep seeing a small white envelope with an A on it on the right hand top corner of my TV screen. I have LCD Philips 42pfl5403. If someone have a solution or seen it before, i appreciate your input.
  • 11 Answers
SOURCE: screen discoloratiom area
It's definitely your VCR that is causing the problem. Move your VCR, if you don't get any results you need to send it to repair.
Posted on Jul 10, 2007
MikeMaierTV
  • 206 Answers
SOURCE: TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Posted on Mar 06, 2008
  • 13433 Answers
SOURCE: I just hooked up a
it should be, Antenna -> Converter -> vcr -> tv.
Posted on Jun 07, 2008
SOURCE: I have been given a
Found a download PDF manual on Philips' website
Posted on Jun 13, 2008
  • 3 Answers
SOURCE: DTA800B1 how or should I
instead of putting the converter box on ch4 ,put it on ch3 same as the vcr . set the converter box channel for the channel to be recorded, program the vcr to channel 3 for the channel to be recored. set the time and date on the vcr progam.tv does not need to be on for the program to be recored but the converter box needs to be on.
Posted on Aug 30, 2008
I would like to record a show/shows on tv using my lg gc990w 6 head hifi stereo vcr . A work colleage has told me I cant do this because I am trying to record a high definition channel. Is this true or...
you can try setting your tv to record and your vcr to record at same time,,,i have digital tv and set record time,,then on vcr set to record avi at same time,,the only problem is the tv turns itself on when timer starts,, hope this helps and makes sense,,cheers.
Feb 08, 2011 | LG Televison & Video
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
I have the nokia 5800 xpressmusic which i have just got. in the top right hand corner there is a envelope flashing, when you click on it its says simcard memory full, i have all ready cleared the numbers...
If you've just put your SIM card in your Nokia 5800, you may have noticed a flashing envelope icon at the top of the screen.
This icon indicates that the SIM card's own text message storage is full. This doesn't actually cause problems on the 5800 because it stores its messages in the phone's own memory, but the envelope can look a bit annoying.
To get rid of the flashing envelope:
1. On the standby screen press the white menu button.
2. Select "Messaging"
3. Select "Options"
4. Select "SIM Messages"
5. Delete some or all of the messages from the SIM messages folder using the Options menu.
This should make the flashing envelope go away. You only have to do this once because when the SIM card is emptied it won't fill any more, as the 5800 does not store messages on SIM cards.
Nov 19, 2009 | Nokia Lands Phones
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
I can only get snow on my tv screen
Does your controller turn the tv on and off?
Dec 16, 2008 | Microsoft Xbox 360 Console
AIM 54 cm TV locked
Not sure if this is the same TV as I have but keep the "music" button down until the screen comes back. Hope it helps.
Oct 08, 2008 | Panasonic CT-2789VYD 27" TV
Motorola RAZR mieterious message icon
Check and see if someone has sent you a picture message that you haven't downloaded yet. If you have one, it will tell you that you haven't opened it, and all you need to do is download it if you want that to stop. Or you could just delete the message.
It's not a big problem that will mess up your phone, it's just telling you something. (:
Jun 21, 2008 | Motorola Mobility RAZR V3
Grey icon; top righthand corner
It probably is a mode you are in, try switching your modes, is this the picture you are seeing up in the right, the gray icon?6719dfc.jpg
Nov 17, 2007 | Pentax Optio M10 Digital Camera
Built in tv guide channel
It's possible there is a flaw with your TV but more likely the listing information is being blocked. Many cable companies do this, likely another reason to force you into buy/leasing their equipment. This should not be a problem with OTA.
Jul 11, 2007 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
338 people viewed this question
Top Televison & Video Experts
Electro Med Services...
