Question about Hitachi C25-RF35S 25" TV
Hitachi natura tv problem
Hi my tv keeps turning its self off, i turn back on and it can stay on for some time but when i put animation on the tv it cuts out all the time like every couples of seconds???
someone said to me about resetting the tv but have no clue how to???
can some help as we love our tv
  • hit-tv Jun 09, 2008
    this is my tv
  • kezzy200 Oct 07, 2008
    i have the same tv & the same problem. It works fine when conecting the wii to the front of the TV, but as soon as i connect a scart, it keeps going to sleep mode, please help, because i also love my tv. thanx kez
SOURCE: Hitachi 43FDX10B rear projection tv
Do you have a cable box which turns on and off with the tv? If so is your cable box input on the video 4 mode? If that is the case look under the video menu for advanced selections, you will see a selection for auto/on/off for video 4, select off. Check manul under video and it will explain also.
Posted on Dec 10, 2007
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
  • 979 Answers
SOURCE: Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Posted on Feb 15, 2008
SOURCE: Hitachi model 55FX48B
Just had the exact same thing happen to me.
Posted on Apr 01, 2008
  • 927 Answers
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Posted on Sep 09, 2008
Tv goes off by it self can turn it back on
hi make sure the timer is not on , the other fault could be capacitor or a dry joint in the power supply ,i'd look for a tech in your area hope it helps
regards
shaun
Mar 26, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
Hitachi 51F520 keeps turning off and on
hi, the tv is not set on sleep timer is it. the other fault could be a dry joint or a swollen capacitor a loose board with the power off you will need to do a visual check make sure you've got a good light hope it helps
regards
shaun
Dec 06, 2011 | Hitachi 51F510 51" Rear Projection...
Does there exist a manual for Hitachi Natura Tv, progressive scan on net?
Please intimate exact model number of your Hitachi TV to look for user manual. Model number would be written on sticker pasted at back of TV.
Jun 15, 2009 | Hitachi Televison & Video
Unlock zone Hitachi DVD player
I can't get my hitachi natura to connect to my dvd player using RCA plugs. I can't actually see how to switch to the av mode! Please help - small children going BONKERS!
Apr 13, 2009 | Hitachi DV-P745U DVD Player
Tv comes on then just shuts off will turn right back on
hello it sound like theres may be a dry joint probably in the power supply you would need a strong light and a magnifying glass and soldering iron and some solder
shaun
Apr 08, 2009 | Hitachi 50GX49B 50" Rear Projection...
Natura Hitachi 36in TV - Not turning on.........
Check the flyback transformer for cause of the odor . If it is a cap look for a cap that is buldging at the top of it . The flyback is the transformer with the red lead going to the picture tube . You might see it is cracked or a tiny hole in it . Good luck
Mar 04, 2008 | Televison & Video
(Hitachi 43F300) Turning its self off
Sounds like it is going into shutdown mode. When the TV power supply and system control sense an overload the system control turns the TV off to prevent further damage from happening. I suspect it is a shorted convergence IC. It would be best to call a service center to repair the TV.
May 18, 2007 | Hitachi 43F300 43" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi C25-RF35S 25" TV Logo
465 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
