I have a Frigedaire room ac model # FAA087P7A, one year old, and is not blowing as cold as it did when new. Is there a way to check the Freon ? What other possibilities ?
Donot ever buy frigiaire products they donot work
Posted on Jun 17, 2008
  • 3 Answers
To check the freon which is actually called refrigerant, (freon is just a brand name) you would need a set of gauges. But to buy refrigerant you need to be EPA certified. You would also need to find the leak and repair it. Are you sure the compressor is even running? You can usally here it kick on after the fan comes on.
Posted on Jun 09, 2008
How do you make your old wall air conditioners blow refridgerated air again?
I'm pretty sure those work just like the AC unit in a home or car/truck/SUV. If they are low on Freon the cooling unit (compressor) will not engage...so the air that it IS blowing is just recirculated air (the air from the room). Try looking for a HVAC company in your air...see if they can give you a (free) estimate. If it's not the Freon, then it's possible it could be the compressor is bad.
Jason
Oct 04, 2014 | Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
My ac in my 2006 saturn ion blows cold air when its under 80 degrees outside but when its over 80 degrees it will blow warm air sometimes and cold sometimes what could be wrong with it
You likely need to charge the AC with freon. If it has been a year or three since you've had it checked, it is probably low on freon and needing to have some added.
Aug 08, 2011 | 2006 Saturn ION
AC wont blow cold air/ 1996 dodge grand caravan es
the control module is bad it has an intermittant fault replace this and it will work fine
Aug 17, 2009 | 1997 Dodge Caravan
No cold air blowing from RUDD UPKA_)$#JAZ
A few things to check; Clean filter, make sure none of your ducts have blown loose in attic area, or under house. If neither problem exists check to make sure your compressor is kicking on, it makes a deeper toned noise than fan motor. If it's not coming on, call A\C company, preferably the installer to check it out. Good luck.
Jul 10, 2009 | Heating & Cooling
No Cold air from 99 Montero Sport
replaced clutch, driver ac belts on 2000 montero sport a/c is still not blowing cold any ideas
Jun 30, 2009 | 1999 Mitsubishi Montero Sport
Ac blows inconsistant ford 3.8l mustang 1995
have you had the freon level checked? Sounds like it is low on freon. My lincoln did that and it was just low on freon.
Jun 24, 2009 | 1995 Ford Mustang
AC is not blowing cold air. How do I add freon?
What you will be looking for (in your engine compartment) looks almost like a large valve stem that you would see on a tire. It will probably have some kind of plastic cap on it.
It shouldn't be that difficult to find. You may want to search for an engine compartment diagram for your make/model/year vehicle.
Mar 19, 2009 | 2005 Hyundai Sonata
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
